Tranny whine
Bought an s13 with an SR...and previous owner claimed the throw out bearing was the cause of the whine and it would do it while the clutch was engaged... So I ripped it out and went ahead got a new CC stage 2 and resurfaced the fly wheel ordered a new clutch sleeve release bearing and throw out bearing from FR threw it on and cranked it up ... When clutch is dis-engaged tranny kinda chatters almost the same sound as the thowout bearing sounds ... But I can drive it fine and still goes into every gear... Doesn't whine 4 or 5th gear... Also When I pull off on first gear the wheels kinda lock up and clunk... Don't know if it's a welded dif or cause of the transmission... Any input would help! Thanks guys....
