1988 Silvia K's build
Hello Zilvia! I probably should have started posting here a while back, but there's nothing wrong with starting now! There's still lots to be done and a lot of time.
I'll be documenting the progress of the Silvia. The intention for this build a combination of a restoration and upgrade/better than stock. I got the car last year before I PCSd from Yokota, Japan. I'm currently in Germany and bound for Arizona a year after this. It was a battle to decide to never modify the car or build it up. I choose to build it, but with good quality and clean parts. It's intention is to be mostly a show car, Sunday driver, with occasional track usage. Onto the pictures, what you all came here to see! Shortly after I got it. ![]() Of course I couldn't stand not hearing anything. Do-Luck exhaust goes in. ![]() Some of the parts for the brake swap. ![]() Z32 brakes and 5 lug swap with the bonus 330mm front rotor upgrade. ![]() Once in Germany for a while, I started the S14 Non-HICAS subframe swap. Out with the old. ![]() So clean! ![]() Got everything sandblasted and primed. Not that color is not the finished product! ![]() and where i'm about right now. Just waiting on more parts to finish the subframe swap. ![]() SO! As it sits now, i'm waiting on parts from another seller since Enjuku can't seem to figure out how to give me the correct parts. Otherwise this subframe swap would be on it's way! Future plans
A little more. Some wheels to get me by while...
![]() These get refinished in black with new silver bolts. ![]() and after owning the car all the this time. I never took an engine bay pic. So here it is. ![]() |
@FourtyKid - Hey! I figured I might find some Redditors on here.
@crash n' burn - I'm in Spangdahlem and thanks! Currently working some magic to get a 180SX over here. Plan is to import it to the US year with the Silvia...not to mention getting that certain car from the docks tomorrow ![]() |
![]() Join Date: Jan 2010
lucky man!!
Before:
![]() After! ![]() ![]() ![]() ![]() and some Muteki lugs for when it all goes back together. ![]() Looks like another delay though. Each one of the RLCAs have a bushing facing the wrong way. So now I have to take it back and have it reversed....more delays.....never going to get done. |
![]() Join Date: Feb 2008
VERY clean car my friend! Good luck with the build! The rear of the car is looking nice even though it will be seen rarely. I love attention to detail!
Thank you! A large part of this project is keeping everything in excellent condition, even if it's nearly there already. I was going to buy a bunch of BallerBolts replacement bolts to freshen things up further but a few bad reviews has me hesitant to order...
I got a little something from Clear Corners that should arrive in the coming months. Pics will come when it arrives! |
It's about time this subframe started getting put back together!
I have to mention. This build was highly inspired by doyle4281's thread. So a thanks goes out to him for putting together a nice thread with good ideas and lots of pictures! Applying that anti-seize. Corrosion prevention and it will make disassembling this in some years a breeze. ![]() New wheel bearings, since the old ones were totally shot. Nismo 50mm extended studs, also since the previous ones has a couple trashed. ![]() Everything getting properly torqued down to factory spec. Don't worry, I know not to fully tighten the bushings till the weight of the car has been applied! ![]() All new parking brake goodness! Such a pain in the ass to assemble.... ![]() |
iam mc loving this!!!
#19 |
Thanks everyone!
@hyp014, you can pick up the new bolts here. They're actually BBS bolts but they fit better than anything else I've tried. Looks like i'm going to try to get the subframe in today. Good thing too because the Skyline's performance was pretty damn disappointing so far. Almost 3 wheeling! ![]() |
#20 |
![]() Join Date: Sep 2005
![]() ![]() ![]() ![]() Feedback Score: 20 reviews
Beautiful car and clean base to start with. I love seeing these resto-builds.
A bit random, but is that Robbie Nishida in the background? ![]()
BRICKHOUSE PRODUCTS
IG @brickhouse_products |
#21 | |
It's fun doing it and much better. It's great when you don't have to stress on rusted bolts! I'm going for a OEM+ build. A lot of stock items retained for looks but some little thing will be upgraded over stock. Good eye! Yep, that's Robbie and Jimmy Nishida in the background there. Made some progress today. Still not done just yet. Nice pic of the clean axles. ![]() About to go in! ![]() Just about done. Just brakes, subframe collars, coilover adjustment, driveshaft, exhaust left. I'm having a problem with the S14 camber arms hitting the coilovers. I took the arms off for now and once the coilovers are mounted I'll see if they fit. EDIT: Yep, the S14 arms won't work with my coilovers. So it's another delay. Gotta get that bushing swapped out into the S13 camber arm and repainted. ![]() Last edited by Volks; 06-01-2014 at 09:33 AM.. |
#22 |
Progress
Got the bushings swapped over to the S13 camber arms. ![]() The handbrake is mounted again. ![]() New Brembo blanks! ![]() On to attempting to tighten all the bushing down with the weight of the car applied. ![]() |
#24 |
Just tried to double tap the screen to like that post. Haha. Keep it up man.
BRICKHOUSE PRODUCTS
#25 |
Lots of fun today.
I was planning on swapping the radiator and hoses out, but it turned into a much larger project. Turns out the water pump was leaking. Got it pulled out and a chunk of the gasket was missing, that explains that! ![]() |
#27 |
Thanks man. I'm trying! lol
Got it back home with the new rad installed but.... ![]() it's pissing worse than before. RTV gasket has failed! ![]() Swapped my wheels over. I haven't driven it yet but these tires are a million times better than what was on the TE37s. Federal 595 RS-R 255/35r18s all around is what is mounted now. You can't really tell but the rear tire alignment is totally fucked. There's mad toe in and i'm pretty sure some positive camber. So that'll be first on the list to do after the new water pump in in! ![]() ![]() Got an order in for a few things while i'm having the front end of the engine apart.
#28 |
Alex! It's Mason. Car is looking nice man, you've always kept your shit super clean! By the way, do you still have the VW from back in the day? Either way, when you get back state-side, hopefully you bring that thing back home to the beach, at least once in a while. I know its a long drive from AZ, but you should come visit everyone. Plus you need to check out all the new stuff i'm throwing into the 1J car, maybe even take it out for a few laps. Keep up the work man, now that I'm back where I have internet, I'll keep an eye out for updates.
#29 | |
Nah, I had to sell it before I left the beach. Still pretty disappointing how I only got $1,400 for how clean it was! Man...I'll definitely be visiting but I don't know if I'll be driving the Silvia all that way. It would be cool to check out your car and even drive it. I'll keep you updated if i'm heading out there, for sure. Taking the car down to the shop for a rear alignment and front bushings install. The GKTech fan didn't work unfortunately. It needs some sort of spacer to clear the power steering pump orrrr just go back to stock fan. |
#30 |
A little update.
Got the front bumper patched up from the shipping damage. ![]() Got the engine bay detailed too for out local car show. ![]() Snagged from S15 loot from a guy who just totaled his car. Floor mats, door garnish, and rear seats!! Pictures due soon. Going to get some super mint S15 front seats as well. |
