![]() Join Date: Apr 2004
Thinking about a VE head swap, but here's a question I haven't seen answered anywhere.
WHY exactly do some people say you need to swap in a VE oil pump/front cover and all the crap that goes along with that (machining crank pulley, oil pickup tube etc.)? Is the timing chain drive different? In which case I'd need a VE chain? Or can one just run the RWD oil pump and be done with it. I can't see the slightly higher oil pump demands being that huge of a deal since the bypass opens so early in the midrange anyway (keeping you at ~60-65 psi when hot).
The VE pump is a much higher volume pump, just like the S14 is a higher volume pump than the S13. Only one stud will line up in the front pump cover if you use the S13 pump with the VE head as well. As far as I know the chains, sprockets/guides are all pretty much the same. SR20DE cam gears work for the Sr20VE cams, so I'd say it's safe to say they are...
My SR20VET |
So it is a VE oil pump really necessary? Or just kind of one of those "it'd be nice" like 19mm wide rod bearings?
FWIW, I probably won't venture over 8.2-8.4k RPM with upgraded valve springs, and that'll be rare.
Since it's part of the oem motor and it's a high out put pump I'd say it was necessary. set the limiter to 9k with aftermarket springs, The most I rev too is 9k but some people rev them to 9500-9600 with the oem pump (fwd n/a car). Also you need VE pistons if you plan to run a bigger cam other than the stock 2.0 VE cam. You could prob run SR16VE non N1 cams on the DET pistons but I have heard mixed reviews about this.
![]() 95 240sx RB20 415whp 91 Nx2000 VVL yo |
Does the VE pump have a higher pressure spring in it? I know the gear flows more oil to hit the bypass sooner, but the DET pump in stock form hits the bypass stupid low at like 3-3.5k RPM with hot oil. After that it's a constant 60-65 psi.
I guess I'm just not seeing a huge need given the cam switch is probably going to happen quite a ways above where the bypass is flowing oil. Would just a slight shim of the DET pump work out if the VVL stuff needs a bit more pressure to operate?
VE on the left GTiR on the right VE pump GTiR I think it might just be more than a higher pressure spring in the VE.
sr20-forum has a good VVL section and SR20forum has some good info in the archives too. I had a gauge on my VE it would read 90 something on cold start then 35-40 at idle then back up to 90 while cruising.
#10 | |
On street it'd max out around 90-100 PSI consistently.
I never watched the gauge after 4800 so I couldn't tell you how high it hit once the VVL engaged. My gut tells me it's for the VVL, if you kill it then you could just run the DET pump.
#12 | |
20V cams are or slightly longer duration than N1s, and offer less lift. which in theory should create a broader powerband. i would never trust a DET oil pump to do a VET's job IMO. |
I'd say for piece of mind, just run the pump... It's a little extra insurance for your motor. If you're going to do something, you might as well do it right.
My SR20VET |
Can you do the grinding of the stock crank pulley by hand, just taking some out with a grinder, or is it something controlled to a tight tolerance that would need a machine shop?
I've seen diagrams that just show a slightly tighter fillet radius being needed. The VE oil pickup tube is the bigger PITA in my eyes.
#15 | |
Regardless, N1 cams are garbage for Turbocharged applications... Use the Factory P11/P12 cams and call it a day unless you want to go Kelford custom grinds.
Def, If you have access to a machine shop/lathe, I'd chuck it up in that and mill what you need off, I would imagine it would only take a few passes to get what you need. I'd suppose you'd be able to get away with the S14 oil pickup. From what I can remember when I installed my VE pump cover, the Mazworx modified pickup has a larger OD pickup but the bolt holes are spaced the same distance apart as the DET's. Dont hold me to that because it's been awhile and I can't confirm it without disassembling my motor (not happening). There's also a double o-ringed plug that goes into the back left of the motor (looking at the front cover). You'll see the one I'm talking about when you set the VE head on the DET block.
My SR20VET |
#17 |
I didnt say N1's. SR16VE and SR16VE N1 are 2 different cams. As for the N1's sucking for turbo I have heard different and wont really know till I get there.
#18 | |
Honestly, I'd like to get my hands on a set of the 20V cams and I think that would just about do it. My motor previously made 491whp with an all stock setup. I think the higher lift and duration of the 20v cams would squeek out a little bit higher peak power.
My SR20VET |
#19 |
#21 |
One of the bolts in the head won't line up with the cover, a custom oil pickup must be made, and you'll have to machine your crank pulley. Is it really worth the extra work to do it? In my eyes no, but perhaps some see it as a valuable upgrade. Honestly though, why waste money when the S13 oil pump works just fine? If you want, there are PnP upgrades for it, instead of swapping the whole cover and machining of misc pieces.
My SR20VET |
