#37 |
Here is for the S14:
Front: Origin Lab (type 3) 45mm vented fenders - fit nice and good quality, had to drill holes for mounting Rear: Origin Lab (Type 3) 55mm overs - horrible fitting, lots of sanding, wouldnt even sit right and when trying to mount you can see stress cracks forming. So I cut them up and had to mold them to the car as there was no other option ![]() ![]() (disregard the zenki hood) ![]() ![]() ![]() ![]() |
#39 |
#40 | |
#42 |
![]() Join Date: May 2012
anyone have detailed pics of charge speed rears on s14? I was planning on going origin, but now I'm unsure... eastcoaststeeze pulled them off nicely, but if charge speed has better out of box fitment I'm sold.
#45 | |
![]() Join Date: Sep 2009
Used these, rivnuts, to mount them for easy removal (9 per side) Mounted |
#47 |
M5? The part number is from Fastenal and I used SS button head bolts. I totally took the idea/part #, whole shebang, from a Modified Mag. article they did about putting overs on a time attack S2000. (March '10 was the issue)
#49 | |
Those look great, those are the 50mm charge speed ones, right? I'll add those to the OP later. May I ask why you decided to go with rivnuts over just rivets? Sent from my iPhone using Tapatalk |
#50 |
Thanks guys. Correct 50mm chargespeed's, I went with Rivnut mainly for cleaning. I get a lot of small stones behind them.
I'm so bummed about the quality of the origin type 3's. I was thinking about selling mine for those but IDK now. |
#51 | ||
30mm Tatakadasi rears on my coupe, with 20mm silvia fenders for the front.. fitment is junk. Fronts: 1) Front wheel arches are not even from side to side (caster is dead even) 2) Lots of air pockets/defects in the right front fender. I watched chucks of the fender fall off/chip away as i was fitting it to the car. I would drill, and the fender would chunk. 3) Driver front fender is also molded 'short' in relation to the hood, the gap is very large compared to the other side. 4) Couldn't get the fender to line up right with the bumper, i'll have to add material to the flange to be able to center the fender. Rears: Fitment with these is a bit better, but still lots of work required to get them on properly. This time, the pass. rear fender seems to be cut short, and warped? I'm guessing this is due to the provision for the gas flap. Driver side rear over fender went on much easier, but seems to have more flare than the pass. side. Would not buy this crap again at 350 per pair, would rather buy the shitty ones from VIS if I have to work the fenders this much to get them to even come close to fitting.
#52 |
![]() Join Date: Apr 2013
I've searched for this stuff already but not coming up with anything, but Can anyone upload a s13 hatch with chargespeed 50mm rear overs ? Cant find many. I got a decent sized dent on the body line of my hatch so i feel like the best way to fix it is overfenders. And if anyone can tell me how 18x10.5 fit with 50mm overs as well too that'd be great.
#53 |
FineLine Tuning 50MM
S13 Hatch $299 before shipping. Think $350 shipped Tatakidashi reps pretty much, or very similar. Actually fit pretty damn well. A little bit of trimming but that's it really. I'd say 7/10 at minimum. Don't really have any other close ups but I can get some if someone wants to see them. |
#54 | |
![]() Join Date: Feb 2010
I Did riv nuts for my overfenders we use all the time for other builds. they help with everything
S13 Coupe, S14 Kouki Crew Chief jeff Jones Racing |
#55 |
![]() Join Date: Jan 2015
#57 |
18x9.5 +15 with a 30mm spacer. Rear quarters were fu*ked is why I went with overs.
#58 |
30 up front would be great 25 is not to bad in the rear
| comparison, guide, overfender, overfenders, s-chassis |
