Overfender Guide
Ok I've searched the forum and google and have not found the concrete info I'm looking for. What are all the options for rear over fenders(in my case for an s13 coupe, but I'm fine with someone who has knowledge about s13 hatch/s14/s15 posting so it may help someone down the road!). So far the ones I know of are the Origin overfenders(I'm sure there are many other brands and options I'm missing.)
Origin Type 1 (Available in 50mm) Origin Type 2 (Available in 50mm) Origin Tatakadasi fender pull (Available in 30mm/50mm) I have no clue what any differences are in these three. After doing some image searching on google I found mixed results but the trend seemed to be: Origin Type 1 - Smooth sides Origin Type 2 - Stepped sides or Sides with a fine body line in them (not sure which one) Origin Tatakadasi fender pull - Appears to be type 2 with a molded 'roll' to the fender If you add please try to put your info in this format and i will add it to the original post Brand and name of overfender(Sizes its available in) What s-chassis it is for Price A description of its physical appearance/what makes it different Hopefully we can get some concrete knowledge on this subject and possibly get this to be a full "Overfender Guide" sticky for all the s chassis' Overfenders Guide: S13 Origin Lab type 1(50mm) s13 coupe/hatchback $306 Thin body line(similar to chargespeeds), follow window/trunk lines, wrap around taillights Origin Lab type 2(50mm) s13 coupe/hatchback $306 Stepped side, follow window/trunk lines, wrap around taillights Origin Lab type 3(55mm) s13 coupe/hatchback $395 OEM body line, flared fender, follow window/trunk lines, wrap around taillights Origin Lab Tatakadasi fender pull(30mm/50mm) s13 coupe/hatchback $306 Appear to be smooth side with flare around wheel well(simulated fender roll), follow window/trunk lines, wrap around taillights Extreme Dimensions "Gt-R" style/Duraflex B-Sport(50MM) s13 coupe $299 Which would be a copy of Origin Type 2, fitment was surprisingly good, they are thin and VERY flexible. Only Issues i have with them are: 1. They do not have the body line (the little bead in the middle of the body) 2. The gas filler cap area needs a bit of work, for the cap to fit (not a big issue though) Overall very pleased with them. -japslapsilvia VIS Drift X(30mm) s13 coupe/hatchback $249 Look like they follow window/trunk lines, wrap around taillights and have OEM body line through them chargespeed(50mm) s13 coupe/hatchback $499.00 top notch, fitment was absolutely perfect. very little prep work required, I primed and wet sanded once and they were ready for paint. they wrap around the tail lights, and come up to the door. notice how the lines ride the window and trunk lines perfect. they come with a nice gas door assembly, but im a ricer and i like how it looks sunk... overall I love them. -jsu1012 S14 Origin Lab type 2(50mm) s14 $306 Follow window/trunk/taillight lines, with a stepped side. In my opinion the fit it absolutely horrible. A ton of sanding and straightening has to be done so things line up how they should. Last edited by StoopidLoose88; 04-11-2015 at 07:01 AM.. Reason: adding information |
![]() Join Date: May 2011
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 13 reviews
If you really did google and looked at the lines and styles of the overs, you'd have each down within 30 min. but i'll play along.
here's mine: Brand: chargespeed , 50mm s13 coupe price:$659.00 shipped. quality: top notch, fitment was absolutely perfect. very little prep work required, I primed and wet sanded once and they were ready for paint. they wrap around the tail lights, and come up to the door. notice how the lines ride the window and trunk lines perfect. they come with a nice gas door assembly, but im a ricer and i like how it looks sunk... overall I love them.
Thank you for contributing, car looks great, I actually follow you on Instagram already lol. How were your overs fastened? Most I've seen are riveted but yours almost look factory smooth.
#4 | |
![]() Join Date: Jan 2015
Maybe you guys can help me. I'll of course will measure and fine tune myself, but some insight is awesome. 1993 Nissan 240sx S13 (will 5 lug swap) I have Front: 17x10 +5 (215/45/R17) & Rear: 18x11 +25 (245/40/R18) . What spacer/overfender sizes would you think would be the best match. I want atleast 50mm rear fender, atleast 25mm front. Thanks!
#6 | |||
![]() Join Date: Nov 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
Here is mine, they are Extreme Dimensions "Gt-R" style 50MM, Which would be a copy of Origin Type 2.
Fitment was surprisingly good, they are thin and VERY flexible. Only Issues i have with them are: 1. They do not have the body line (the little bead in the middle of the body) 2. The gas filler cap area needs a bit of work, for the cap to fit (not a big issue though) Overall very pleased with them. this is just tape holding them on I used Rivit Nuts to fasten them (low profile allen head screws) Sorry i dont currently have any better pics of the back
I have authentic origin type 2 50mm rears on my s14 and in my opinion the fit it absolutely horrible. A ton of sanding and straightening has to be done so things line up how they should.
#11 | ||
They look really good though, I'll add the info for these to the original post! Quote:
Congrats, you're the first s14 to post in this thread! Lol but that surprises me, previously I had never heard anything bad about origin products, but it has been noted and I'll post this in the original post, thanks! Sent from my iPhone using Tapatalk |
Extreme Dimensions Duraflex M-1 Sport 30mm Rear over fenders for S14
Fitment-9/10 Fit very well once bolted on and I just had to fix a few very minor cracks. Required no trimming. Only held on with tape Primed and block sanded Test fitted with only 8 screws Painted and installed with 25 rivnuts/screws per side
when you need 25 rivets on each side i dont think its a 9/10 fitment lol. driver side in front of the wheel the panel is cut at an angle or what?
#15 | |
9/10 wtf???? Both sides have obvious differences in how they are cut. On the drivers side there is a gap in the front of the fender well. Whats up with the passenger side around the tail light? Looks like a kid cut it with some scissors. |
It's extreme dimensions... wasn't expecting perfect looking parts. Maybe I gave it too high of a rating then if you guys really think it fits that bad. For the price I got them for and they fit right on out of the box, I think it was worth the money. The main reason I got them was to cover up my quarter panel bondo job by a previous owner.
25 is just about what every one else uses.
#23 |
I Think so too. The previous owner just told me he ran a 27mm (1.06) spacer with a 50mm fender and the fitment was perfect. My 1" spacer should be around the same. Shouldn't make a huge difference. I always have the option to tuck my 18's
Link to his pictures: #/f/showthread.php?t=594403
#25 |
First photo is a 30mm over fender on the REAR placed on the side. I think 50mm rear is the idle size. OKAY. The front... front Wheels. 17x10 +5 with a 1" spacer. I think 30mm front will be perfect with some camber.
[IMG] [IMG] [IMG]
#26 |
![]() Join Date: May 2012
is the 1" spacer necessary? seems like if 50mm overs were perfect with 1" spacers, 30mm overs should be really close without 1" spacers... might have to run without camber, but I don't personally see that as a bad thing.
#27 |
#28 | |
[IMG]
#29 |
#30 |
Do they make 30mm front s13(pop up) 180sx front fenders? 30mm would be perfect. I've been doing some searching and haven't found anything but 30mm rears.
How is VIS fitment? I could go 25mm with a ton of camber lol
| comparison, guide, overfender, overfenders, s-chassis |
