| South Western States Arizona, California, Hawaii, and Nevada. |
So today I took my car over to sideways performance in Santa Ana to have a y-pipe fabricated in order to mate my sikky headers to my Apexi catback exhaust and be done with the swap since my welder took a dump. I talked to him over the phone and explained what i wanted and he said he can fabricate one with no problems for $250 or a few bucks more. I towed my car over there because I was running with open headers. I got there and showed him a reference pic of what i wanted and he said that that was what he was planing on doing.
Heres the reference picture And heres what i ended up with. They cut my catback.....WTF Did I mention that he said that this is the best way I would have clearance and the best flow and heres the clearance |
![]() Join Date: Aug 2013
So, what did he say when you showed him the reference picture compare to the BS you have in the other pictures?
#7 | ||
That's the first thing I asked. I told him I didn't want crushed bends. I asked him if he had pre mandrel bended pipes and he said they did. I think what they did was droved it across the street and have the muffler and radiator shop do it. Oh and apparently I wasted his time. |
man im sorry to hear... iv been to that shop and it is a f-ing mess in there... there is trash and $h!t everywhere!! i feel sorry for who ever goes to that shop or has been there.
![]() Join Date: Sep 2006
Trader Rating: (30)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 30 reviews
Lol it's been a long time since I've been around Zilvia, and this is the first thing I see in my local community. There is a long as reputation with this company, I'm extremely surprised he is still in business. I've never had any work done there, but I've been there and met the owner, he seemed like a cool guy but it also seemed like he actually lived there at the shop. This was back in 2009 though.
These guys did a 2JZGTE VVTi/R154 swap into my SC300. Let's go over the miracle story of how the hell am I still alive and how is my motor running:
- 1350 driveshaft adapter place had 1 bolt holding it together (should be 5 W LOCKTITE!) - Worst oil pan sealing job I've ever seen in my entire life and even on google. My oil strainer had chunks of sealant in it - No coolant overflow tank installed. Instead, they used a rusty screw to block the hole from the hose coming from the top of the radiator - Coolant was a dark brown (almost oil-like). Did a coolant flush immediately, and felt 10x better about the cooling system - They didn't lube the aluminum lug nuts that they installed on the wheels that I purchased through them, so they fused with the wheel studs - They made a "Sideways Performance" hybrid harness inhouse for my swap, but I later confirmed with Tweaked that this was their harness 100% (quoting Tweaked via email, I attached a pic of the harness for them to see it) - The motor mounts had no supporting bolts installed. Yes, I said that correctly. I figured this out when I drove it 80 miles with pretty aggressive vibrations, and told myself that it was from the polyurethane material in the mounts, but come to find out, there were no bolts holding my motor down, just the trans mount, and speaking of that... - The trans mount needed to have two holes tapped/drilled in order for it to work with the R154 in the SC. Apparently, they didn't have the resources to tap/drill it, so they used a GRINDER to grind out chunks of the mount in order to get the bolts to the trans through.. I haven't even gone through everything yet because I'm pissed about what else I'm going to come across... |
![]() Join Date: Jun 2003
Trader Rating: (129)
why? cuz a decade of sketchy work and bad experiences isn't enough to convince you to stay the fuck away?
