4-500hp built tread!
i'm starting my build and attempting to reach 4-500 crank hp
S14 blacktop sr20det Cp piston 86.5mm (should i go 8.5:1 or 9:1.. will be runnin street 94 oct gaz) eagle rod stock stroke acl bearing (hole set) oem seals all around cupper ringned deck Bc stage 2 cam Bc spring+retainer tomei rocker arm stopper 3angle valve job arp head+main rod bolt top mount synapse Vband manifold Gt3071r @ 22psi (dyno only, will daily boost @ 16psi) 3'' straight exhaust tial 44 ewg z32 Maf Five0 750cc injector Walbro 255lph fuel pump correct me if i have choosed wrong parts or mix of parts or have a better combo.. time has come for me to order my piston and my main question, i'm hesitating between 8.5:1Cr or 9:1Cr ?!? thanks in advance! |
#2 | |
![]() Join Date: Nov 2010
![]() Join Date: May 2008
It will depend on the tune... and what engine management do you want?! But yeah, you should be able to reach that goal with that setup.
For your CR... keep doing some research... you will see the pros and cons of it. put at that boost, I would personnally go with 9:1... You might reconsider the BC Cam... they're not the best on the market... Anyway, GL! See ya, Frank
Life is a beat to beat |
i wanted hks, but they're back order for who knows how long, i don't want to upgrade to solid lifter and all the blablabla needed :P 22psi is only for number, plus meaby a few drag races :P
has for the tune it'll be nistune |
for 500hp your injectors will almost be maxed, id go with some 1000cc ones to be safe
im using injector dynamics ID1000's, theyre amazing youll have to switch to top feed though
'92 240sx w/'93 SR Blacktop /// '94 RX7 FD3S /// '11 370z RIP |
#9 | |
:Pif you guys wanna fallow my build tread you can fallow it here! Kouki S14 BUILD thread |
#12 | |
Obviously already stated is your injector issue, upgrading to 1000cc would be ideal. maybe check out a 5857 precision turbo as there new billet series are kicking ass. as for compression 9.1 seems to be the best choice. |
#13 | |
you can do either without having to upgrade to solid lifters
tomei poncams IMO are better only cause im running the procams haha plus tomei is cheaper
Sard does 850cc sidefeed... I'm using them on my setup... you only need to redo the harness plugs and add collars to hold them in place(about 30$ for 4 collars).
Also, you could add a Greddy Intake to the list! Frank
Life is a beat to beat Last edited by army240; 07-28-2011 at 09:28 PM.. Reason: added stuff |
hmm...i didnt know SARD had 850's
theyd be good for the 400hp mark, but trying to go to 500 they would be way over their duty cycle...up to about 440 give or take he would need 1000's if he wants to run 22lbs of boost
#17 | ||
![]() Join Date: Dec 2004
Trader Rating: (58)
InjectorDynamic stuff is super nice!
#18 | |
Trader Rating: (58)
And now I'll address things to change:
Eagle stuff is no better than stock stuff. I'd stay away from it. No need to O ring at all. Apexi or Cosworth Headgasket is plenty. Total junk. JWT cams and NO valvetrain modifications (yes, you can keep stock stuff), or you can add JWT springs if you wawnt. The general rule of thumb is try and keep cam and spring companies the same, as they have been tested together. BC stuff is cheap junk. Not needed. May be a bit small if you really turn the wick up on the turbo
#20 | ||
where can i purchase it? ''Eagle stuff is no better than stock stuff. I'd stay away from it.'' then what do you suggest? ''No need to O ring at all. Apexi or Cosworth Headgasket is plenty.'' i dealed it with the machine shop.. they gave it for free, with that done, i can put on a stock Headgasket! ''Total junk. JWT cams and NO valvetrain modifications (yes, you can keep stock stuff), or you can add JWT springs if you wawnt.'' i already have the Bc spring and retainers... better sale them and put the stock on back on it? |
#21 |
should i just put in pistons and bearing, keeping crank and rod stock? piston ringland are totally destroyed on the 4th piston, so noway i can reuse them :P
i've heard oem rod were good for 500hp (maxed out tho) since your saying eagle aren't better then oem, i should save that 3-400$ for something else then?! |
#22 |
crank is good, just get it resurfaced and balance. almost any machine shop can do it and its like $20
manly rods are good you should save on the eagle and go manly =]
#23 |
#24 |
i just built mine so i wouldnt have to later on
if you plan on dd-ing a 500hp car i would just to be safe
#25 |
![]() Join Date: Mar 2010
Location: Back IN FL, bring nice cars to the fail state!
Mines up and running....still breaking it in....Shooting for around 400whp but whatever it is it is.
Mahle Pistons (8.5:1) .20 over Eagle Rods/ARP HDW Nismo 740's Enthalpy ECU Top Mount precision 50 trim with Peakboost mani setup tial 44mm ewg Stock Head with HKS 272 Step 2 i/e, BC springs retainers Cometic Head Gasket (I know well see how long it lasts) ARP Head Studs Denso Supra TT fuel pump Tomei Small FPR All new oem seals, new OEM main cap bolts,new rockers, timing chain set, etc etc. Mine came with a freddy manifold and sard 850's and AEM standalone, but I wanted to simply it and go with the enthalpy ecu and stock intake. Its a lotta work and plan on having a backup fund because you will find shit you need that you didnt plan on. |
#26 | |
#28 | ||||
Trader Rating: (58)
JIM WOLF TECHNOLOGY, INC. / NISSAN PERFORMANCE / NISSAN RACING /INFINITI PERFORMANCE Check their site out. JWT S4 cams with your 30r turbo will work great. Quote:
Another thing to add (and it may be common sense to some of us) but getting a 2nd car/beater is the first mod I'd make.
#29 |
i already own a second car/winter beater wich is in mint shape :P i'm having a slow build wich i can only work on weekends once in a while soo if its more expenssive it doesn't matter, will only take a lil extra time before takin it out, but i also want it out asap!! :P
has for the cam, there's S4 ans S4HD, thats the difference, i assume your talking about the S4 not the S4HD right? Last edited by Saico; 07-31-2011 at 07:16 PM.. |
#30 |
Im running 22 psi with a gt3071r with stock internals and just 740cc injectors and tomei poncams with a pfc and it runs strong and a daily driver. i wouldnt be afraid to run 20-22 psi with your setup as long as you torque and make sure u do everything right problems tends to happen alot quicker when your running high hp.
