s14 to s13 Ecu jumper harness problems
Im in the process of trying to make one to go from my obd1 s14 to an s13 ka24de ecu. Im running into a problem I have both plugs ready to go tore the plug out of an s14 ecu and soldered wire to the pins. and cut the plug off an s13 harness. My problem is finding info to figure out which wire on the s13 plug goes to on the s14 plug. I have been unable to find a full pinout of either ecu and even with the pinouts I have im already running into problems with the pinouts not naming wires the same and the s14 having alot more wires trying to figure out which wires are needed obviously all of the s14 pins will not be used. But im just spinning my tires if anyone has made one of these successfully or has info plz share It would be greatly appreciated thanks
