![]() Join Date: Jun 2010
What can I use as a high tension cable to check timing on my Sr I really don't want to rip the valve cover off and where can i dl a fsm thanks guys
Man w/ CTSV & a Car Seat
What do you mean high tension cable? You mean where to tap to get a timing signal from?
Nissan Factory Service Manual (FSM) |
Find a spark plug wire to plug into the coil and then on to your spark plug. Then you can put your timing light on that.
My SR20VET |
