Alright so I have A S1 Motor. Im planning on making it a S2 because it came with S2 coils. Here is my set up so far and if anyone can shed some light on things that i need to change or if its even possible.
Wiring sprecialties pre made harness combo with s2 coil harness s2 coils s2 maf s1 ecu metal halfmoon CAS freddy mani with adapter stock s1 TB AND Q45 TB with sensor (which one would be best??) From what I have been reading from multiple websites this set up would work. Just want to make sure im not missing anything. Thanks. |
![]() Join Date: Mar 2010
![]() Feedback Score: 29 reviews
You'll be fine the only difference wiring wise is the coil packs I think. And you have that covered. You have to run s2 ecu because the ecu contains the (igniter chip).
Uhhh it may be. For some reason I remember discussing this when I got a s2 motor. I thought that the ecu had something to do with it.
Basically this is my thought process: ( and by no means am I an expert, I just tinker in my garage so if I'm wrong please correct me) S1 ecu sends spark signal to the chip. The chip determines which coil pack gets the signal for spark. S2 the ecu determines which coil gets the signal. And sends it directly to that coil. And the igniter built in ups the voltage or something. I might be way off and feel real dumb. But I thought the ecu had something to do with it. Cause if that's the case you could run s1 ecu on s2 and vice versa. So I really do think there is a difference with the ecu's and I was pretty sure it's because the coil pack/ ignitor none sense. But again I have very little experience with this stuff. I'm just building my car haha. I don't own a shop or claim to be smart. |
Any way yes I believe the igniter is in the coil pack I just think the ecu has something that determines which coil get the signal. But idk haha I'm really curious now as to what is right
![]() Join Date: Jan 2011
S1 and S2 ECU's are interchangeable.. Harness and Coil packs are different less you get a wiring specialist harness. Cas is the same if you have the half moon/star.
Alot of people dont know this but. They way Japan nissan see's it Series 1=Igniter set up, Silver CAS Series 1.5= Non igniter setup, Silver CAS Series 2=Non igniter, Plastic CAS |
I'm new to nissans and especially rbs. And I picked up a series 2 motor series 1 ecu. I was looking through ecu pinouts. Number 113 pin on series 2 ecu is for the variable timing control solenoid series 1 ecu doesn't have a listing in pin 113. Left me confused as to the variable valve timing working with series 1 ecu on series 2 motor. Any issues with this?
