Got into an accident, tried selling my car and couldn't get the price I wanted so now I'm saving her. Behold
![]() Join Date: Feb 2004
This thread blows. Seriously WTF? No pix or explanation on what is going on. Are we supposed to read your mind on what you want help or opinions on? What does "REAR END BAD" entail????
The Architect.
![]() Join Date: May 2006
Trader Rating: (392)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 392 reviews
Looking at that rear end, it's clear that you have frame damage.
The buckle by the C-Pillar is also a clear indication. Is it fixable? Sure. Is it worth it? Probably not. |
progress
Every thing I've taken off thus far I'll take pics of tomorrow but it's like all broken, I've got a new sub frame with solid bushings and oem RUCAs traction and toe rods will be Peak performance, Tein front tension rods, S13 VLSD, and OEM RLCAs. Pics will be up soon thanks for the input guys I appreciate it
I know this feeling. I got rear ended and my insurance ended up totaling the car because they 'thought' it had structure damage. I ended up getting a chunk of change and got the car back and I had it fully inspected and only minor things needed to be replaced like the lower control arms, got a replacement rear bumper and reinforcement, got the car fully repainted and alignment done too. That accident was like 6 years ago and yeah the title is rebuilt but I still daily it and drives fine, no uneven tire wear or issues at all.
The tough part is gonna be getting the rear end fully aligned if there is structure damage, which that appears there has been. If the rear of the car is out of whack and the front is straight the car will probably feel and drive wrong. Then you gotta worry about tires wearing unevenly also a strain on the differential, drive shaft, tranny. Not saying it can't be fixed but it can be costly and you might end up with issues when after repair. Good luck OP Last edited by jza80king; 12-03-2014 at 03:28 AM.. |
This car will never be right. I hate to say it but it's beyond repair.
My SR20VET |
AFC #1
![]() Join Date: Oct 2003
Try and bolt that new subframe in place before you go all nuts with bodywork. By the looks of it I think your rails are done for.
| 240sx, kouki, rebuild, repair, s14 |
