![]() Join Date: Oct 2013
Tips for drilling s13 dash for gauges.
hey guys I am planning to install a set of defi gauges that I bought from camryonbronze into my Silvia's dash. And I am curious if anyone has any tips on how to get a clean cut. I plan to use painters tape to cover the holes, then draw on it to align my holes, drill a pilot hole. Then use the hole saw in reverse at first. (Someone online said that's a good way to start cutting into the hole?)
Below is the look I am going for, if you guys have any other tips or tricks to pull this off I would greatly appreciate it. I just don't want to ruin/destroy my mint rhd dash. thanks. thanks! ![]() Last edited by e30gangsta; 03-07-2019 at 09:56 AM.. |
![]() Join Date: Jun 2003
Trader Rating: (129)
sounds like you've got it pretty well figured out already
if you really wanna go the extra mile, get a trashed/cracked dash and test drill on that first |
![]() Join Date: Jan 2010
not sure if your referencing this thread specifically, but it looks like youre on the right track!
https://www.diymobileaudio.com/forum...e-my-dash.html id be mostly concerned about the hole saw being too aggressive and taking extra material with it. it looks like the concern is addressed. |
![]() Join Date: Oct 2004
Truthfully, I tried.... very similar method. My dash was 100% mind and just started cracking..... where the holes were drilled.
I dunno I truthfully the vinyl is SO brittle and the underlying foam as well... Its risky no matter what... sorry to say....
Turn and Burn!
Hopefully this goes without saying, but be sure to use a straight edge to align the holes.
1995 S14 - project | 2007 TL Type S - DD | 2000 Trooper - offroader Last edited by Shift_grip; 03-07-2019 at 01:51 PM.. |
#8 | |
![]() Looks rad! |
Do the 3 holes instead of 4. Imo looks better, dash will be stronger in this place and it will be easier to do because of one less hole to drill
Oh and you can still use your oem ventilator duct behind the gauges. Basically when it comes to drilling holes with a saw you have to do it VERY FAST. Other than that you will just mess the dash surface around the holes. What i did is i made a smaller hole (54mm for example) with a saw and then made it bigger up to 60mm with a dremel tool. It is more time consuming but a safer method for sure.
@kamil_ftcln |
Car is running on a standalone, all of the engine protection parameters are on anyways. I bought the gauges before switching to an ems. So yeah I guess you can say its for the gram bro lol
If i were you, i would drill the hole about half the size you want, and use a dremel with a sanding head to finish it. Reduces the risk of cracks, and you can still get a clean finish. I did that to my B-pillar panels in my s13 to run s14 seatbelts.
![]() Join Date: Oct 2007
I remember doing it on my brothers civic
I cut the top layer off and exposed the bare plastic of the dash and then just used the right size hole saw on the plastic of the the bare dash, so you won’t rip material off Also I left the hole a little smaller then the gauge so it’s a snug fit I would do an angle adaptor to it so you can have a good view of them from the driver side Sent from my iPhone using Tapatalk
Lots of things I'll never get. This one of them.
Tuners are big bullies
#15 | ||
![]() Join Date: Oct 2008
Trader Rating: (131)
I think people ran gauges in this location long before Instagram existed, haha. NOW, all of this being said, I regret drilling into my mint dash. No issues with the drilling process or cracks forming down the road, but I wish I had not done that to my clean factory dash. e30gangsta, I think you are all set to go- just like we talked about on Instagram. I wouldn't stress! |
