oil temp sensor in drian plug?
i picked up a apexi oil temp and i was told that the sensor would directly bolt in to the stock drian hole plug in the sr oil pan. i have done alot of search on the DIY of a oil temp install, and no luck with this plug. can any one point me in the right direction. thank you
Jason Hill |
![]() Join Date: Dec 2002
Some senders come with an adapter to screw in place of the drain plug. The problem in doing that is you've got that much more part hanging off the lowest point of the pan that's just asking to get knocked off.
![]() Join Date: Aug 2006
![]() ![]() ![]() Feedback Score: 1 reviews
GReddy oil pan has a sensor fitting, right besides the drain plug. I say change your oil pan and get GReddy, good for cooling, drifting (has baffles, which prevents the SR from going oil hungry...) also allows you to add another quart of oil, which is always good for our SR motors
![]() Steve. Last edited by djcobra; 08-25-2008 at 12:31 PM.. Reason: mistake... |
thank you for your help guys. id like to swap the oil pan but cant realy afford it now. im just trying to get ready for big willow this week end and i was thinking it was an easy quick install if it just bolts in to STOCK location of the drain plug
![]() Join Date: Oct 2005
in addition to the baffles it has windows! great for when your sliding so your pick up dont get starvation.
if anything you can always get an oil block adaptor from greddy. =)
![]() Join Date: Dec 2006
Is there any benefit to having the temp sensor in the oil pan as opposed to near the oil filter, or vise-versa?
would there be that big a difference in temperature?
