Fried DOHC ECU's
I have 2 DOHC Ecus that are fried. both are fried on pin 36 and that is the Ignition Switch 12v.
Now I didnt check them before I installed to see if they were previously fried. Im currently trying to solder one and see if i can fix this issue with it.
Can someone tell me what to check to see if MY IGNITION is the one frying them. Also If I plug in a SOHC and it DOESNT FRY would you say that they were previously fried or is there a major difference between dohc and sohc ecu
Originally Posted by Hoffman5982
Did you check the potato fuse located in the front right corner of your gas tank?
Originally Posted by RB33
No i haven't. To be honest i didnt know there was a fuse there. Thats not a fuse for the fuel pump is it?
