Old 06-17-2019, 01:01 PM   #1
Masonsx
Masonsx is an unknown quantity at this point
Another KA Timing issue
I've read through pretty much every KA timing issue thread and checked everything and still I can not seem to get my timing correct.
I bought a newly rebuilt motor and swapped it for my old KA. My old KA was in time.
To make a long story short, it seems like I'm a tooth off. However, I can line up the rotor to the #1 plug perfectly. When I do this the timing acts like its too retarded. One tooth counter clockwise and its too advanced.
I went as far as re-installing the timing chain. Lined up all marks on all sprockets. Cams, Idler, Crank... The process is simple enough. Same issue though.
I adjusted my tps to .5V Adjusted my idle to around 750. I even compared timing lights and they both read the same. I truly dont want to think that it jumped a tooth as soon as I started the car again.
The distributor is from my old KA. I've replaced to rotor button and distributor cap. I also used the crankshaft pulley from my old KA.
Any ideas what might cause an issue like this other than mechanical timing being off?
Masonsx is offline   Reply With Quote
Old 07-21-2019, 08:50 AM   #2
kyral
kyral's Avatar
kyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nice
you haven't really said what the symptoms are. just "it seems like I'm a tooth off"
what is the car doing
The Game
you lose haha
kyral is offline   Reply With Quote
Old 08-06-2019, 07:36 AM   #3
TEN_2nd_BUSTER
TEN_2nd_BUSTER's Avatar
TEN_2nd_BUSTER is an unknown quantity at this point
its a timing issue, until its not... grounds? idk, kinda need more info like kyral said...
BROKE, BUSTED, AND DRAGGIN.... but i fix it
TEN_2nd_BUSTER is offline   Reply With Quote
ka24de, timing
