Car still overheating. Just replaced radiator, water pump and thermo.
Okay guys I need your help. Here's the breakdown:
Car overheated suddenly one day. Plastic OEM radiator cracked. Purchased brand new Mishimoto radiator, Nissan thermo and water pump. I didn't test the old thermo but the spring looked faulty. Replaced the water pump since I was getting in there anyways and better to replace it now even though it was working fine(currently at 138,000 miles). Replaced everything, buttoned it back up, purged the air out of the bleeder valve. Warmed up the car let the thermo open and topped off the coolant. Shit is still overheating, WTF??? Upper radiator hose is hot while lower hose and water neck are cool to touch. Help a brah out. EDIT: PROBLEM SOLVED. I think we can say that on a KA you have to bleed the system, run the car till the thermo opens, then fill and bleed again and you should be good to go. Last edited by Bunnywith240; 12-10-2011 at 10:39 AM.. |
#2 | |
If so, was your car on an 80 degree incline you did this? If not you should do it again .Also check the CTS with a multimeter. |
I'm experiencing a similar issue. Try and see if the coolant circulates with the t-stat removed. My car just started overheating on me recently (radiator, water pump, and t-stat are less than a year old.) Coolant just stopped circulating. Replaced the t-stat with a new one, and same thing. Today I just took the t-stat off and now coolant is circulating. I'm starting to suspect a heater line/heater core might be clogged.
#6 | |
OP, check for circulation with the t-stat on. If there isn't, remove the t-stat and then check. |
![]() Join Date: Apr 2008
Theres defective oem nissan thermostats floating around,a cold lower hose means the thermostat isnt opening,when u run without a thermo,both hoses are somewhat warm because ofthe constant flow,so normally,both hoses need to be warm to hot,i have 3 NEW,yes new nissan thermostats,put all 3 in a pot and boiled water,inserted temp gauge and one opens up at 76c other 2 dont START to open till about 95c,so by the time its fully open,the gauge reads 120c.,i bled the air out a million times till I thought to test them,i figuered new nissan oem parts wouldnt fail,the one that works looks different,the other 2 have the outer parts like non oem,but I purchased them at nissan......also make sure you installed the thermostat correct,the jiggle valve on the stat needs to be at 12oclock
#8 | |
Appreciate the help fellas. I'll check back in and update tomorrow. |
![]() Join Date: Aug 2009
Could be a number of things check your rad cap first learned this yesterday in my automotive class at uti its cooling system week lucky for you so yeah those caps are what create pressure in the system if not some other causes of overheating could be incorrect timing, lean air fuel mixture, exhaust restriction and incorrect cam timing so could be anything after you exhaust all efforts check those few things good luck
Man w/ CTSV & a Car Seat
Pop the T-stat and check to make sure it opens. Boil it in water and see if it pops open. Use a cooking thermo to make sure it opens when its supposed to.
#11 | |
Okay gentlemen, good news. The second bleed attempt worked. Ran the car in idle mode and held 3KRPM revs a few times and this car is purring like a kitten. No more overheating and in this weather, the car is running very cool. It amazes me how rocksteady this car is at idle. The motor doesn't move AT ALL.
Keep an eye out on it still, my shit overheated the other day, let it cool down and it didnt overheat again. Thought maybe the radiator was low or something, it was completely full. HG might be going out so its being sporadic.
have you tried putting a new Temp gauge in the cluster? i had the same problem and replaced ever single cooling component and it still claimed to over heat replaced it and boom it was fix..
