#631 |
![]() Join Date: Sep 2009
![]() Feedback Score: 22 reviews
I notched my core support to slide my radiator maybe an inch and a half forward, and I don't have a condenser, but I'm sure I could make one fit if I wanted/needed to.
And I agree with bullfrog about th tstat. Because it opens at a lower temp initially, it helps with most overheating issues. Like I stated, with stock thermo I was running around 210, and with the mishimoto, I'm only running around 160. When I track my car, I don't want 210 to be a starting point, imagine how much more heat it will create. So since I can start at 160, that gives me +50 degrees to play around with and not have to worry about overheating. Now if you have a blown headgasket or some other cooling issue, then yes, the low temp thermo will just be a bandaid. Also, care to clarify your scammer status/3 previously banned usernames? (天国) |
#632 | |
Wait, so the mishimoto thermostat dropped your temps with no other changes?! |
#633 | |
![]() Join Date: Apr 2007
#634 |
![]() Join Date: Aug 2008
Does anybody know where I can find the 1jz bellhousing flywheel inspection covers other than directly from toyota? I read a thread from a while back that people were getting some cheap carbon fiber alternatives off of ebay but I cant seem to find anything anymore.
#635 | |
Yup! OEM is around 82 C I believe, and the mishimoto one is rated to open at 62 C. Now that's only about a 36 degree F difference but when cruising the difference is nearly 50F haha. I have a koyo n flow radiator with dual FAL fans |
#637 | |
Welcome to Driftmotion! |
#639 | |
#642 |
![]() Join Date: Apr 2003
Trader Rating: (33)
Have you thought about using a Civic condensor? Its smaller than the OEM unit but still functions very well. I have seen these used on High HP Evo's and have seen a few 240sx running them with success as well. This should free up some space and allow for adequate cooling. However, there was someone on here using an OEM setup down in Florida and had 0 issues using the Koyo, E-Fan, and Mishimoto setup. Let me see if I can dig up the info.
#643 |
I live in Florida. But have no AC lol (that's what my xB is for
) And tengoku, you said you have an s14 right? As far as I know, you have a little bit more clearance in your engine bay. I have two friends in this area that have 1j's in their 14's, and I don't think they had to notch their core supports at all. (also, I only notched my core support for fan clearance so I could run my dual FALs as puller fans like they were originally designed) Also, you sure your condenser fan is kicking on? And how's your front bumper/ airflow to the condenser? Maybe you can build some sort of fresh air intake tube that lets cool outside air blow onto the condenser to see if that solves your problem. I know billion makes kits that are basically a huge velocity stack with (basically) drier tubing that you can use to route air lol Sounds kind of silly but it helps. I had a small oil cooler mounted on the backside of my front mount on my old 180, and I used a billion air duct setup and it worked perfectly. |
#645 |
Still no luck!! We did almost everything; flushing the coolant, cleaning the fins, eliminating the thermostat, aligning IC, condenser, and radiator like | | instead of | \, taking off the hood, connecting the fans directly to power, and yet no result.
As I have mentioned before, it only overheats when A/C is on (cruising). So here are my questions: 1. Do condensers put out enough heat to where it hinders the radiator from cooling? 2. Should I consider using a civic condenser instead of the stock S14? How much smaller is it? Because the S14 condenser covers the whole Koyo radiator. 3. Should I purchase an oil cooler? |
#646 |
![]() Join Date: Jul 2009
oil cooler yes. also make some ducting to go between the radiator, fmic and bottom of the front bumper to basically force air thru everything. a cooling plate on top will help when you make a lower air dam
#649 |
Measure from the bolt hole to the inside of furthest point out on the bar (the part that would be in front of the oil pan). Also from the bolt hole to the sway bar mounts.
#650 |
Trader Rating: (33)
I believe I looked at an aftermarket civicl condenser and it was approx. 1/2 the size of the stock S14 unit.
OM1kron also used a Porsche condenser unit. |
#651 |
I came to a conclusion that my dual flex a lite fans are not pulling enough air for the setup. The temp started to rise with no A/C when I quickly let off the throttle and put the gear in neutral after a heavy acceleration (up to 6k full boost).
#656 | |
Though, you might be better of buying a cut harness on the cheap and taking any salvageable plugs off of that. |
#657 |
![]() Join Date: Jan 2007
Now maybe its just me But Are the motor mounts supposed to look like this? eBay mounts to add.
*Would have bought excessive mounts if I known they made them months ago. I tried switching them.and moving but I can't imagine how this would line up straight in the bay.
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
#658 |
IIRC, you have to shuffle some stuff around on the block to get access to the right holes for one of the mounts. If you look, you should see a second set of holes with the correct spacing. Or at least that's how my Zerolift mounts were, and I believe the Ebays are a copy of the ZL mount.
#659 |
![]() Join Date: Mar 2007
STUPID late to this thread....
![]() I started my swap in my S13 while I had my S14 up for sale. Long story short, sold the S13 first, kept the S14. Started the 2J swap summertime 2011, and its currently just...sitting there ![]() making the mounts: I want to do a single turbo and have 80% of the parts ready. I still need the driveshaft, PTE turbo, and AEM w/sensors. The most expensive parts lol. Hopefully Ill be able to get the remaining parts soon to have the S14 done! Heres the S14 w/SR: Here's how it sitting: ![]() ![]() ![]() |
#660 | |
Anyone know where to get an e10 connector w/pigtail!! I need this to get my motor started. I don't have any lexus' or Toyota's at our junkyard like that.
