#7591 | |
![]() Join Date: Nov 2005
So I bought a Wisefab rear kit, and I've been told by several people that they bend easily, which I was very perplexed about, since they don't seem to be giving any of the pro guys issues with wheel to wheel contact and such. I went to look at my knuckles and they've definitely been updated since the pictures on the first post. Pretty obviously strengthening if you compare the two. Nice to know! ![]() |
#7593 |
![]() Join Date: Dec 2013
How do I get more angle out of my gktech lca? I am currently at 55 degree and if I go any more wheels will rub. I have the longer s14 arms but they are adjusted all the way in do I just lengthen then out? Wheels are 17x8 +35 gktech drop knuckle and gktech super lock lca
#7594 | |
![]() Join Date: Mar 2009
This is the roll center, suspension pickup, and steering angle modification thread.
#7596 |
Ummmm, you can adjust the toe curve with the traction rod. Without modifying the toe arm mount, it's doubtful you're going to be able to get the car to toe in under compression, but you can certainly get it to toe in less.
#7597 | |
They are very simple but makes it a total no brain centering your steering rack to the wheel for max travel in both directions. Any time that you do an alignment slap that thing on there and now the alignment guy (or you) cant mess it up. This is especially helpful when on a digital alignment rack or using smart strings. Track side if we feel that the toe is off based off driver feedback, you will slap the rack centering tool in and visually look at each wheel to see which side may have moved and attack that side with the adjustment to get the alignment back the specs that it had when it left the shop.
[email protected] Last edited by Bink Industries; 04-23-2018 at 03:37 PM.. Reason: forgot some info |
#7598 |
#7600 |
![]() Join Date: Apr 2004
...a lot of load actually goes through the front crossmember. I'm not sure that's providing much rigidity to the chassis now.
#7601 | |
#7602 |
Given that bending produced by the chassis trying to deflect the strut towers inward, like you get when cornering, is going to be proportional to the width of the cross member cubed - I'd say you took a ton of rigidity and strength out of it. Say the original crossmember was equivalent to a box that's 4" wide, now it looks like it's maybe equivalent to a box that's ~0.25" wide in the center. That means you now have 0.25^3/4^3 = 0.024% the stiffness in bending.
Even if you say all that extra gussetting on the bottom adds to the equivalent of a 0.5" thick box section in bending, you still only have .5^3/4^3 = 0.19% the bending stiffness. There's a reason the OEM cross member is a large tubular structure. You can't just hack out huge parts of that and say it's good because you put some incomplete fusion MIG tacks on pieces of it.
#7603 | |
Also lol at incomplete fusion. Those heat marks on the underside are weld almost coming out the back of the plate. Full penetration. The only reason the beads are tall is because I circle the weld. |
#7604 |
I was talking about a BOX section, not the width of one leg of a piece of angle iron, which is pretty much what your crossmember is now. It’s called the second moment area of inertia to bending if you want to look it up.
#7607 |
Installed my rear wisefab kit tonight. Lower control arms are a total PITA. I should have checked fitment before I welded up the gktech kit, I'm sure it would have been a bit easier. Prying and hammering were involved, and the rod ends are close to maxed on their articulation, but it should work.
#7608 | |
![]() Join Date: Feb 2012
Trader Rating: (31)
Sent from my SM-G955U using Tapatalk |
#7609 |
Trader Rating: (31)
Almost done with one pickup, then just need to do driver side. On the driver side I was experimenting with having the stock and dropped location, but decided to go with just the lowered bracket alone.
![]() ![]() Sent from my SM-G955U using Tapatalk |
#7611 |
Got some neat pics from my first event in the car last Saturday! Finally got to drift on the Driftknuckles.com Unicorn Knuckles and I have to say they drive amazingly. I had steering angle forever and could really focus on just driving the car where I wanted it. If I actually let it lock out all the way I would start crab walking sideways which felt crazy at first.
![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk |
#7612 |
GkTech V3 knuckle update.....the CTS-V brake swap brackets bolt on to the knuckles with a little modification and new haedware. For anyone interested.
![]() ![]() Sent from my SAMSUNG-SM-N920A using Tapatalk |
#7613 | |
Trader Rating: (31)
#7614 |
www.ctsvbrakeswap.com
To note, I have the S13 V3 knuckles. Sent from my SAMSUNG-SM-N920A using Tapatalk |
#7615 | |
Trader Rating: (31)
#7616 |
A little more clearancing, and had to use allen head cap screw bolts as the tolerances are really close.
#7617 | |
Trader Rating: (31)
#7619 |
![]() Join Date: Oct 2013
Not that I have any experience with this set up at all but, if push comes to shove look into ARP's catalog of hardware. Sure its more expensive than the hardware store, but for instance their 10mm bolts have 12mm heads on them. Can really save tons of headaches.
#7620 |
I cant quite remember all of the sizes off hand, but i bought the hardware through theboltdepot.com. I'll try and post up thr sizes when I get back to it.
| anti-squat, best thread ever, kpi, roll center, steering angle, suspension |
