Old 04-03-2008, 10:21 AM   #1
ludakris
ludakris is an unknown quantity at this point
Rear quarter panel on s13 hatch
I was wondering is it possible to remove the rear quarter panels on the hatch? If it is, is it really hard do? Also if the gurdle underneath the radiator is bent, like pushed in on one side towards the back of the car does that mean i have to get the frame pulled to straighten it back out?
ludakris is offline   Reply With Quote
Old 04-03-2008, 10:23 AM   #2
cronux
cronux's Avatar
cronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to all
quarter panels kind of suck, its like, cut out, cut new one, crimp edge, weld, grind, fill, paint, then realize that you didnt do it perfectly, and go and buy over fenders like you should have to begin with.
cronux is offline   Reply With Quote
Old 04-03-2008, 10:28 AM   #3
ludakris
I would just have done over fenders but the whole thing is fucked from wheel well closer to front of car to the door, the door jams are all bent to shit also. I was hit and run thats why its all fucked up.
Old 04-03-2008, 10:35 AM   #4
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
that actually sounds pretty bad. You might want to rack it to make sure the unibody is still actually straight.
New Video
Buy my mounts!
Old 04-03-2008, 10:49 AM   #5
ludakris
Now i can take it to a good alignment shop to rack it and check the unibody right?
Old 04-03-2008, 06:49 PM   #6
ludakris
pics of damage
Well here are pics of the damage, any suggestions on what i should do?
Old 04-03-2008, 07:01 PM   #7
ludakris
Here i can only upload one for some reason.
Old 04-03-2008, 08:41 PM   #8
JDMS1lv1a
JDMS1lv1a's Avatar
JDMS1lv1a is a well-known jackass
what cronux said^^ but I think its not too bad.Ive seen alot worse get fixed.
Then again that quarter/door jam looks like it'd be hard to fix and get perfect with just pull/bondo,bodywork etc.
idk,cut and weld a new quarter?new door? take it to a body shop
JDMS1lv1a is offline   Reply With Quote
Old 04-03-2008, 10:06 PM   #9
BoostedCoupe
BoostedCoupe's Avatar
BoostedCoupe can only hope to improve
I read somewhere that the corner can actually be removed. No its not just unbolt and bolt a new one up. You can drill out all of the spot welds and the quarte will come off. I have never done this so im not sure on where they all are. This is a really hard way to do it. it would be much easier to just cut it out but you asked how to remove it.
92 vert converted 5speed and other little things
BoostedCoupe is offline   Reply With Quote
Old 04-04-2008, 06:32 PM   #10
Pacman
Pacman's Avatar
Pacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura about
Time to find a shell. S13's are cheap. A bill like that isn't worth it unless you know body work. Sorry for your misfortune.
In search of a Zenki S14 right side (passenger) fender and straight hood that are rust free.
Pacman is offline   Reply With Quote
Old 04-05-2008, 09:38 AM   #11
Devil Man
Devil Man is an unknown quantity at this point
yeah thats going to be a pain in the butt big time to fix that one.
Devil Man is offline   Reply With Quote
Old 04-09-2008, 06:03 PM   #12
silentstyle1
silentstyle1 is just really nicesilentstyle1 is just really nicesilentstyle1 is just really nicesilentstyle1 is just really nicesilentstyle1 is just really nicesilentstyle1 is just really nicesilentstyle1 is just really nicesilentstyle1 is just really nicesilentstyle1 is just really nice
Send a message via AIM to silentstyle1
what you need to do is take the door and the hatch off, take all your rubber mouldings of around the door trim, then comes the fun part of finding all of the spot welds, if i remember correctly, there are about 25-30 there should be a crap load on the door frame, about 8 at the wheel well, and probably 10 or more on the inside of the hatch. what you want to do is go to an auto store and ask them for a drill bit for cutting spot welds, it will look basically like a mini drill bit for cutting circles in wood.
You want to drill the spot welds out about half way so that the inner part is still there for you to weld the new one too, after drilling the spot welds out you will need to use a chisel and chisel the two pieces apart.
If you have never done bodywork, it's gonna be really hard to do, and probablly wont come out right at all, in that case your best bet is to bring it to a body shop. If you have done it before, provided there isn't much damage done to the door frame, rocker panel or inner part of the quarter panel it should be a very easy thing to do.
I think the only hard part will be getting the rocker panel off of the bottom of the quarter without doing any damage to it.
Good luck and let me know how it works out for you.
well im sitting in my car in the garage wathcing a movie on my mac thats sitting on the hood eating homemade french toast on 18s gettt some
Nice to know I've got a 30k VA transformer all to myself with 100A 3-phase if I want to start building Cybertron or something in here.
silentstyle1 is offline   Reply With Quote
