Old 03-19-2008, 01:49 PM   #1
beeracing s14
beeracing s14's Avatar
beeracing s14 is a glorious beacon of lightbeeracing s14 is a glorious beacon of lightbeeracing s14 is a glorious beacon of lightbeeracing s14 is a glorious beacon of lightbeeracing s14 is a glorious beacon of lightbeeracing s14 is a glorious beacon of lightbeeracing s14 is a glorious beacon of lightbeeracing s14 is a glorious beacon of lightbeeracing s14 is a glorious beacon of lightbeeracing s14 is a glorious beacon of lightbeeracing s14 is a glorious beacon of light
mobil 1 0w-30 gas saver?
has anybody tried it? does it do what it says on the label as far as gas saving? or is it some marketing BS?
beeracing s14 is offline   Reply With Quote
Old 03-19-2008, 01:50 PM   #2
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
they're true but if you're worried about gas prices you shouldn't be tuning your car
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 03-19-2008, 01:53 PM   #3
beeracing s14
so youre saying youve actually gained more miles with this oil?
Old 03-19-2008, 03:10 PM   #4
shade
shade's Avatar
shade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond repute
Go research before you ask. Try searching "oil viscosity" on Google. Good luck.
shade is offline   Reply With Quote
Old 03-19-2008, 03:41 PM   #5
SoguRacing
SoguRacing's Avatar
if used for the correct situation "yes" you will gain maybe 3 more mileage. i wouldn't use it, my oil needs to be thicker. if you're using it for a daily driver then its ok.
Old 03-20-2008, 07:56 PM   #6
sunnys14
sunnys14's Avatar
sunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nice
Yes you will save gas a bit.
At the same time you can use that money you saved to save up for a new motor because your engine bearings won't like the thin oil.
sunnys14 is offline   Reply With Quote
Old 03-20-2008, 09:05 PM   #7
louisdaboois
louisdaboois's Avatar
Trader Rating: (28)
louisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfection
Feedback Score: 28 reviews
you might as well run water through the motor.
Working at Jiffy Lube for a few years (back in the day) I have vast, useless knowledge of oil. and it's not worth it, honestly if youre worried about a few nickel and dime srummage of gas mileage get yourself a good tune up: plugs, wires, cap, rotor, fuel filter, air filter, and run an injector cleaner through a good vacuum source (you can search you tube to see the effects of sea foam through the intake). If anything, these things will increase gas mileage like woah, instead of running water, type oil.
louisdaboois is offline   Reply With Quote
Old 03-20-2008, 09:11 PM   #8
SoguRacing
SoguRacing's Avatar
I concurrrrrrr^
Old 03-26-2008, 09:41 PM   #9
guitaraholic
guitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of light
If its 0w-30, should it not mean, that when its hot, it acts like 30 weight. Infact, 0w-30, 5w-30 and even 10w-30 should be the same at normal operating temperature. Infact, the only advantage I see of the 5w and 10w is the fact that it has a smaller range, and thus less likely to break down (the smaller the range, the less polymers are required to keep the oil viscosity constant over a wide range of temperatures), Infact, I can see one advantage of luburation of 0w and that is, it should flow through your engine pretty fast at startup. I have been running 0w-20 for 5k miles now, and the oil pressure jumps right up on start up and hits 30-40lbs at idle till it heats up, then settles to about 10lbs/1k rpm or so.
Another advantage of the 0w-20 is more horsepower, because there is less friction. I will have to find the webpage that had a dyno to prove several oil manufactures and wieghts with dyno number (independant study, NOT the Manufacturer). So you might gain a few (be it not many) horsepower, and mileage.
guitaraholic is offline   Reply With Quote
