Old 09-27-2003, 10:18 PM   #1
Champster
Champster is making a name for him/her selfChampster is making a name for him/her self
1JZGTE swap on a S14
I researched options for a V6/inline 6 motor swap on my 97 240SX. I scratched out the VG series motors because of headaches such as major cutting on my ride along with price to do the installation. My next avenue was going with the RB series motor. I decided against it because of the lack of accessibility of parts and service for the motor in the US. Also because of emissions and I needed something that would be ideal as a daily driver.
SR motors are not what I want so no one can sell me on it, neither the CA.
Since the 1JZ motor is a 2.5 liter just as the RB25, would this be the next best thing for my swap dreams? The motor would more than likely come from a 90's + model SC300. I've noticed that there is a JDM 2000 model 1JZ motor from a Supra on Ebay.
All constructive input would be greatly appreciated. Thanks in advance for your help.
Champster is offline   Reply With Quote
Old 09-27-2003, 10:51 PM   #2
nuttypboy
nuttypboy is an unknown quantity at this point
the 2JZ-GE came in the Lexus SC300. The 1JZGTE motor came from the toyota soarer in Japan. So that would probably mean that if you went with the 1JZ, it would lack of accessibility of parts and service just like the RB25
nuttypboy is offline   Reply With Quote
Old 09-27-2003, 10:54 PM   #3
720_datsun
720_datsun's Avatar
720_datsun is an unknown quantity at this point
Send a message via AIM to 720_datsun
yeah didnt someone post a link on a site doing the 2jz-ge swap? it was awhile ago but they were making a kit for it. if your in cali you could goto mckinney auto. they do amazing stuff. if you got the money they can do it.
720_datsun is offline   Reply With Quote
Old 09-28-2003, 12:01 AM   #4
meme
meme is making a name for him/her selfmeme is making a name for him/her self
i'm picking up a 1991 fastback to start on this. this way the exhaust stuff is all on the passenger side.
meme is offline   Reply With Quote
Old 09-28-2003, 11:21 AM   #5
Champster
i read about this a little more and you are on point. i also read that the JZ motors coming from the SC300 uses a Auto tranny. That I can't get with. I'm reading into a 2JZ also. I know from the jump that this would require a lot of fab work to fit. In the long run I think it would be cheaper and less stressful to have.
Thanks dude...
Old 09-28-2003, 12:40 PM   #6
Dousan_PG
Dousan_PG's Avatar
Dousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfection
Thanks dude...
no that auto in SC is in USA, and it doesnt have a 1jz
you can get 1jz in japan easily. go to venusauto or any importer. its easy
go look at izumida's s14 w/a 1jz. straight pimpin
hypersh1ft's friends and him are putting a 1jz in a s13 (USA) right now. cant wait to check it out!
Aaron
Pink GodziRa
www.geocities.com/pink_godzira
Dousan_PG is offline   Reply With Quote
Old 09-28-2003, 01:51 PM   #7
nuttypboy
SC300 came in 5spd manual and auto. Its just that the 5spd are very very hard to come by.
Heres a guy with a turbo 5spd SC300
http://www.turboforum.net/lexus/
Old 09-28-2003, 02:10 PM   #8
DudeYourSoOOJDM
DudeYourSoOOJDM's Avatar
DudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud of
Send a message via AIM to DudeYourSoOOJDM
Power enterprises timing belt, turbo upgrades fairly easy to find (gotta know where to look), the parts are always there, be resourceful.
330whp w/ bolt ons and 12lbs of boost should satisfy most anyone dont you think?
You'll need a front sump oil pan, otherwise you wont clear the crossmember.
Cullen is waiting for a new water pump for the Rocafella JZSX.....I'll keep you posted on the progress.
Since 2001.
DudeYourSoOOJDM is offline   Reply With Quote
Old 09-28-2003, 03:37 PM   #9
Champster
Thats the same thing that I heard. You can convert it into a 5speed however it is really involved to do so.
If I went for the sourer motor (1JZ VVTI)I would go ahead and buy the RB25DET because I would run into the same issue with parts and service. I also would buy the RB if I lived in Cali because Mckinney Motorsports and MotoRex would have access to parts and service. I live in CO right now.
There is a supra/sc300 forum where a guy in NJ has a S14 with a 2JZ motor in it. This brings up a thought also. Would any one know if there would be a dramatic change in the weight distribution of putting in a 3.0 2JZ motor into a S14? I'm guessing it would be considering the RB25 changes it a bit.
Old 09-28-2003, 04:13 PM   #10
Bill Roberts
Bill Roberts is an unknown quantity at this point
The RB does not change the weight distribution enough to worry about. The engine is only 60-70lbs more than an SRDET. You can compensate by loosing the AC compressor and moving the battery to the rear. As for the toyota engine, what about length of tranny and shifter hole? Driveshaft? Mounts? Those would be my concern to start with and also clearences for the piping. Then electronics..
Bill Roberts is offline   Reply With Quote
Old 09-28-2003, 04:13 PM   #11
Champster
Just so that I am not asking ? and not contributing. This is what I found fellas on another forum about MT/AT trannys with the VVT-I 1JZs.
http://www.i-supra.com/6/ubb.x?a=tpc...1&m=2646076134
For those who are in who are interested in finding out about the JZ motor....
http://www.i-supra.com/6/ubb.x?a=tpc...1&m=6236085283
I will post more info as I read on....
Old 09-28-2003, 04:24 PM   #12
Champster
Forgive me for being such a post whore. Here a sight that has a 240SX with a 2JZ motor in it with pics.
http://members.shaw.ca/kfgroup/240sx_-_2jz.htm
Ahhh...and I finally found it!! A S14 powered by a 2JZ
http://evotuners.com/victor.htm
Old 09-28-2003, 08:54 PM   #13
jayc
jayc is an unknown quantity at this point
I got a ride in this car and it is insain! It was only on it's low boost setting. I would love to have that kinda power in a car 4-500 lbs lighter.
jayc is offline   Reply With Quote
Old 09-29-2003, 10:13 AM   #14
DudeYourSoOOJDM
The tranny actually sits about 1 inch closer to the instruments....a little hole needs to be cut. Driveshaft costs $100-200 mixing toyota/nissan stuff. Mounts....cleverly made using Nismo mounts and a little bit of metal fab, tranny mount was fabricated also. Piping should be cake, even w/ a HUGE front mount, and the exhaust will be easy also.
Wiring: If your a Toyota nut like Curbsurfer is, you have already figured it out by now.
Since 2001.
Old 09-29-2003, 11:05 AM   #15
Red
Red's Avatar
Red is an unknown quantity at this point
I hear that the RB25DET and the tranny make it about 180 lbs more then the KA and tranny...
If you have the cash to look at a 1jz or 2jz I would look at the RB26... It has many aftermarket parts/support that are easy to find...
I'm not sure how much the 1jz or 2jz cost for a clip... but I bet install would be a bit more than the RB26...
thats my .02
http://www.cardomain.com/memberpage/509537
http://www.imagestation.com/album/?id=4287415487
#/f/showthread.php?t=21036
Red is offline   Reply With Quote
Old 09-29-2003, 11:26 AM   #16
019
019's Avatar
019 is an unknown quantity at this point
Send a message via AIM to 019
Re: 1JZGTE swap on a S14
i am aware that this might be a little bit off-topic, but i just have to ask... why do yo uthink you'll have to do major cutting on the car to fit a vg in there? my friend is currently in the process on doing a full vg30de swap (not TT) into his s14. he goes by heinekenns here on zilvia. if you do a search, you might be able to find a post he made when he first placed the engine inside the engine bay.
019 is offline   Reply With Quote
Old 09-29-2003, 12:36 PM   #17
Burmonster
Burmonster's Avatar
Burmonster is making a name for him/her selfBurmonster is making a name for him/her self
Send a message via AIM to Burmonster
my roommate has a 5speed SC300 he is looking to sell, black, 80,xxx miles i belive. If he doesnt sell soon he is boosting the engine, so if you want it, give him a reason to sell. Location is Macon, GA
Fat girls are like scooters...they are fun until your friends see you riding one.
"Did you ever think that it could be that the purpose of your life is only to serve as a warning to others?"
A -> B
Burmonster is offline   Reply With Quote
Old 09-30-2003, 09:36 PM   #18
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
Cant you just use a 5 speed Supra Tranny? You'll need a custom driveshaft anyways.
-m
mbmbmb23 is offline   Reply With Quote
Old 10-01-2003, 06:21 PM   #19
Champster
Re: Re: 1JZGTE swap on a S14
I wanted the TT on the VG. That alone would be an issue in dropping that into a S14. I have a bud that told me he owned a Z32TT and he told me that it would not be worth the hassle. The 2JZ stock already has 300hp plus so I am leaning more towards the JZ motor.
Old 10-01-2003, 11:11 PM   #20
Champster
*Off Topic*
This is interesting. A company that provided parts mostly for an SR swap is now a carrying a small line of RB parts.
http://shop.store.yahoo.com/phase2mo...rts/index.html
Old 10-04-2003, 12:02 PM   #21
crazyikimasho
crazyikimasho's Avatar
crazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond repute
I know where you can find a Japanese 1jz and 2jz here on the east coast if you are interested. Email: [email protected]
***PLEASE NOTE*** I am no longer affiliated with West Covina Nissan.
crazyikimasho is offline   Reply With Quote
Old 10-04-2003, 01:43 PM   #22
019
019's Avatar
Re: Re: Re: 1JZGTE swap on a S14
that makes sense. the n/a vg will fit in pretty well. no matter what you plan on doing, just be prepared to spend a lot of money. sounds like you're set on doing the 2jz. that'd be a really nice swap to do. keep us posted if you actually proceed with it.
