![]() Join Date: Jun 2010
i just put my tein flex coilovers on and i can't seem to adjust the ride height..i've been searching but cant really come across a clear answer..i've searched for hours, even came across the instruction manual from tein but it doesnt tell how to adjust ride height..
maybe im just looking at it the wrong way, but i cant get the tube to turn at all(all locks are loose).. do i have to take the 2 bracket bolts off to turn it?? any input would be great |
![]() Join Date: Jan 2008
Trader Rating: (92)
![]() ![]() ![]() ![]() Feedback Score: 92 reviews
Ride height is adjusted by loosening the lower lock and spin the entire shaft ..exposed more threads on the bottom = cars going down no threads exposed cars lifting up..if you YouTube how to adjust Pbm, it's the same
just unbolt the bracket from the spindle and turn that instead. Way easier that way. I never adjust coilovers with them mounted on the car. I'd rather just take the easy way and pull them off, lower or raise them however much I want, then reinstall them.
thanks for all the input guys..i did end up getting it, it was just a pain because there was dirt in the treads..i learned it's easier to back the bracket down, spay the threads with lubricant, clean threads with brush, then thread it to adjust ride height..those things spin 100% better now.
| adjusting, coilover, ride hieght, tein flex |
