#571 |
![]() Join Date: Jul 2005
They're from speedway motorsports and are ~20 bucks a piece. There's a link to them on the first page.
You have to buy their taper bit too though because they are not the same taper as the OEM tie rods.
![]() Instagram - SJKnoop |
#572 |
See, if you have to get a drill bit to drill the stock taper to another taper, you might as well use a bolt there instead
![]() Anyway, parts going to machine shop this week, so I should have everything on the car by the end of the week. I will report back how the bolt will hold up. Probably going to miss the event this month, which is on Saturday, so I will have to wait till next month I guess, to report back on how the grade 8 5/8 bolts will hold up for tie rod end duties. |
#574 |
Looking at these makes me shudder to think what kind of bumpsteer they will introduce into the suspension geometry. I'm sure though that many of us will never actually get to the point where we will want to correct this aspect of our suspension geometry by moving the steering rack forward any way possible. I am almost certain this setup adds bumpsteer because my Tein inner tie-rods came with spacers that supposedly add steering angle... Well it does, but at the price of additional bumpsteer and those spacers were only about 1/4" of an inch thick each. This thing looks like it's at least half an inch wide PER side. The use of something like this to move the rack forward unfortunately corrects one thing but manages to fuck another aspect of suspension geometry since the inner tie rods are now pivoting about half an inch past the steering rack on each side. However, this is speculation on my part as I'm not sure if a longer tie rod shank eliminates the additional bumpsteer from the inner tie rod being spaced from the rack in that manner. Not to mention the amount of bumpsteer the tie rod is already correcting simply by having the car lowered. Maybe their knuckles had to be redesigned as a result of the new inner tie rod pivot point. Gah. All this suspension geometry corrections/changes are blowing my mind right now. One can correct a problem, but reintroduce an old problem they had previously fixed as a result of fixing another problem. No wonder suspension geometry is sometimes referred to as a black art. This shit is evil and difficult to measure/model accurately for the most part. Of course Driftworks may just deal with the added bumpsteer in their suspension geometry as drift events concentrate around one section of track and if theres little to no bumps then theres no BUMP steer problem right? I think I'll stop now I'm just rambling. |
#575 |
![]() Join Date: Nov 2005
Those do not affect bumpsteer. I think you are confused.
Longer tie rods will not increase your bumpsteer. Not having your LCA and tie rod parallel is what makes the car bumpsteer. This has to do with vertical spacing not horizontal. |
#576 | |
![]() Join Date: Jul 2007
Trader Rating: (106)
1: It was a shitty bolt 2: The spacers that were used were also shitty 3: It looks as though you installed the bolt upside down. The head side of the bolt SHOULD be basically a press fit into the spindle and the thread side should be hanging off the bottom of the spindle. It looks like you had it the other way. 4: it seems that the pivot was spaced down too much. You can only get away with an extra inch or so of spacing using a bolt like that. It's funny how many people are under the impression that you need a 3" spacer to get your geometry good. When speaking about roll center you need to be referencing the roll center heighth to the CG heighth, NOT necessarily the ground. If you dropped your CG a few inches through lowering the car and managing weight you don't need to correct the roll center nearly as much. |
#577 | |
#579 |
Going to the machine shop tomorrow to drop off the parts to get machined, but here are some of the hardware.
![]() 62 degrees of misalignment without having to use high misalignment spacers. That is also a 5/8" grade 8 bolt, which is substantially bigger than the stock ball joint stud, even at the thickest part of the tapered part. |
#580 |
![]() Join Date: Jan 2005
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 6 reviews
This subject always turns into he said she said.....lol. Until you actually try all these mods out on track we will never find out.
1994 FD3S Drift // 945garage // sumospeed.com
#581 |
Look at the driftworks car. Take crank centerline as the CG.
Driftworks front knuckles correct the geometry by 50mm and the arms correct by 15. This places the roll center even with the crossmember, which is pretty much perfect. The rear is obviously different. The problem when people go to correct their roll centers is that they don't take into account the instant centers. When you do, you'll realize that your roll center is quite a bit lower than it would seem. Just taking where the lower arms angles intersect is not accurate, the roll center is at least 2-3 inches lower. |
#582 | |
I honestly do not know the correct answer to my own question. It takes a LOT of measurements and calculations to even get a clue of the length of your roll couple. I simply don't have that capability right now. That being said, from my own research the driftworks front knuckles are spaced more then is needed both in the front and ESPECIALLY in the rear. I would absolutely LOVE to hear from them how they came up with those numbers as I am not convinced that they truly understand what they did. |
#583 |
racepar1 - dude, he just told you why he said what he said.
In any case, I doubt the correction on either the DW's knuckles or what people are thinking about doing are worse than having stock hardware and slamming the car as low as possible to achieve a low CG. If that were the case, people who have those DW knuckles, like mmdb, would be saying their car handles funny. As for the rear knuckles not working with the Z32 e-brakes bit, did you see the reason why DW said the Z32 rear e-brake assembly didn't work? |
#584 |
I think that's his point. This is all just "I doubt" and "probably better" until some one measures their actual CG and posts up the pics that they took of their car at a measured ride height with overlaid angles, and then did at least some rudimentary modeling or bumpsteer/camber gain measurements. Dirt circletrack guys wouldn't dream of stepping out onto the track without a proper set-up measureing session. Why do we demand so much less from our parts suppliers?
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: #/f/tech-talk/147301...d-gto-pan.html |
#585 | |
I'm just saying that if you want your roll center below your CG, and your CG is about crank centerline, then having your roll center even with the crossmember is about ideal. The Driftworks knuckles and arms put it there on their S15 drift car, which is pretty slammed. All I did was this: Now I know that's not the most accurate thing in the world, but allowing for inaccuracies and suspension compression when the car is actually on the ground and I think it's fair to say that the front roll center is just below the crossmember (or somewhere very close). |
#586 | |||
#587 |
I am fully planning - and have been from the beginning - to do a proper measurement/calculation session with my car once I get the motor in and running.
I am going to get the car up on a drive-on lift so I can get the car in whatever position I need it in to get the proper measurements. I'll definitely keep everyone updated with what happens with that. I'm not expecting JGTC results, but I feel confident I can improve the suspension for the better while nearly tucking wheel on 17s.
#588 | |
We're measuring angles here. It's not like you have to make a bunch of complex calculations and plug them into some crazy formula and do a bunch of math to figure it out. And CG isn't even that hard, but no one has corner weight scales to be able to take measurements and weights to find out exactly where the front and rear CG's are. Yes, I know measurements off a car would be much better. I am all for getting the very best parts and suspension geometry, but no one is stepping up to the plate to offer anything else in the way of drop knuckles. Sometimes compromise is all that you can do. I know that I have no way of fabricating drop knuckles. |
#589 |
Since I am regulated as to how much I can correct things like roll center, by the RTA "street tire" class rulebook, I am no longer very concerned with measuring out roll center. I'll just correct it the full inch that I am allowed and leave it at that. My main concern is whether or not I should really do anything to correct rear roll center at all with only an inch of correction in the front. I've decided to just raise the subframe up, like the new SPL bushings, and leave it at that in the rear. I figure that should help the roll axis issue. I may also make spacers so that I can adjust the rear subframe position. I am definitely going to replace the rear balljoints with sphericals so that small adjustments can be made as well.
What I AM really anxious to screw with is the front bumpsteer and rear camber/toe curves. If you have adjustable rear arms you can actually adjust the lengths of the ruca's and toe arms WITHOUT affecting the static camber/toe settings. This can be accomplished by adjusting the cam bolts and re-setting the camber/toe to wherever you want it. I think that by playing with those arm lengths and the length of the trac arm some amount of gains in rear traction can be made. I plan to rig up a plumb bob setup and spend a day on the rear alone. The issue that I am the most curious about though is lowering the toe arm pivot on the rear knuckles. I wanna find a way to mock that up so that I can figure it out. All in due time though as my chasis is basically ready to go on a rotisserie at this point. Not much I can measure like that. |
#590 | |
The problem with trying to guestimate roll center from a picture is that a photographic image is not necessarily the correct to scale dimensions compared to the car. Images get distorted slightly depending on what angle the picture is taken from, lighting, camera lens, etc... I'm sorry, but that just doesn't do it for me, even as an estimate. |
#591 |
not giving a fuck
![]() Join Date: Apr 2007
Trader Rating: (104)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 104 reviews
i need to ask this...because...frankly, i cant come up with an answer...
tie rod spacers... they supposidly give you a bit more angle right? but i dont understand how...if say...ur steering rack/tierods were fully aligned...then u add spacers to the rie rods... my initial thought is, that ur wheel would be front of car "<" rear of car to each other (not to such great degree but u get what im saying) obviously after alignment theyll be "=" to one another... so would that mean, that u cancelled out the increased length the spacers gave you...or am i missing something here?
PSN & XBL GT : Wh0pp3r68 CLUB LEXUS : Wh0pp3r
#592 | |
I bring this up because I was experiencing some noticeable bumpsteer without being too far lowered. After some reading I decided to Remove the tie rod spacers that came with my Tein inner/outter tie rods and doing so helped remove 50% of the bumpsteer I was feeling the rest I know I know is from the angle of the outer tie rod. For test purposes I would always drive down the same stretch of shitty road testing the before and after. So, it's not like I was driving on a different smoother road after I removed the spacers to give a placebo effect of having 'removed' bumpsteer. It helped, I'm happy so I just thought I'd bring that up. SPL has this to say about using tie rod spacers (which the DW product I'm referring to inevitably does) "Note: Steering angle spacers are not recommended for road racing use; installation of steering angle spacers will create a small amount of bump steer due to modified steering rack geometry." Found from the link below. http://www.splparts.com/main4/parts/...tmultilink.htm Hope that clears up what I was talking about. EDIT: Oh and something similar to that effect was also written by Tein in the instructions that came with my tie rods. I just threw them out a little while ago so I can't really quote them word for word. Something along the lines of not using the spacers for street use. |
#593 |
![]() Join Date: Dec 2008
![]() Feedback Score: 15 reviews
They allow the main shaft of the rack to move further in on one side resulting in an extra Xmm on the other side. I thought the same thing when I first saw them but after tearing a rack apart I could see how they actually worked.
#594 |
The Architect.
![]() Join Date: May 2006
Trader Rating: (392)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 392 reviews
Does explain why I felt more bump steer after adding the spacers to my Tein inner/outer rods.
Got a set of SPL inner/outer rods I'll be using next. Won't be driving the car for another year. So much for that. Haha. |
#595 |
I can sort of see the reasoning behind that.
Since the tie rods' overall length will have to be slightly shorter to compensate for the spacers (I didn't think the actual tie rods were spaced further outward w/ the spacers, but instead allows for the tie rods to move further before hitting the stops?), the tie rods now have different arcs than the FLCAs. I'm sure if you were able to space the tie rod ends down in such a way that if you can bring both the tie rod and the FLCA to travel at around the same arc (as close as possible), then your bumpsteer issues should be mostly eliminated. |
#598 |
Wonderful folks over at Skullworks are hard at work on them. They've modified the knuckles to fit the z32 e-brake, and are awaiting parts to fit the sphericals in. I'll post up pix when that happens.
.25 till 3 |
#599 | ||
In my experience, the 240 realm has been more of a try and trust type of affair to me. I've tried and spent a lot of money on new things. But it always comes down to buying parts that racers use, working with professional race shops, and working with the local race fabrication shop. In my opinion, the products from Japan tend to be overhype and over priced. But that's another thread. Sorry bout the rant.
.25 till 3 |
#600 | ||
![]() Join Date: Jul 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
Additionally, the method in finding the vertical CG height will be dependent on how accurate your scale is. Here is a real world example: We did a little experiment on finding the vertical CG height on a Formula Mazda race car with two different methods. 1- the tilt test, and 2- the classic lifting of the rear method. The tilt test is known to be more accurate, and it showed since we already knew the specs of the car. It was dead on. The tilt method though however, resulted in about an inch off (keep in mind this is also a smaller car than a 240 lol). The source of the error was most likely the accuracy of the scales. The ones we used were accurate upto a 1 lb. There was only 2 lb total of weight transfered to the front scales when lifted 10 inches from the ground. 2 lb. Just for kicks, we plugged in worst case + and -, and CG resulted in a couple inch of variation. With the combination of an inaccurate roll center location used with an inaccurate CG location, the final result can be significantly off. A couple inches may not sound alot, but on a smaller scale formula car, it can be dramatic depending what your trying to do with that information.
HouseBuyers365.com Quote:
| anti-squat, best thread ever, kpi, roll center, steering angle, suspension |
