Old 06-30-2011, 12:21 PM   #1
Fred Allen Burge
Fred Allen Burge's Avatar
Fred Allen Burge is an unknown quantity at this point
Are adjustable front caster arms necessary?
I'm going to replace my S13 front caster(tension) rods with new ones (rubber bushing type, not solid) and I'm curious if the adjustable type are really necessary, does lowering the car cause front caster change?
Thanks!
Silvia, built 5.3 turbo, 4l80e, [email protected]
Fred Allen Burge is offline   Reply With Quote
Old 06-30-2011, 12:25 PM   #2
blingbling
blingbling's Avatar
blingbling is an unknown quantity at this point
Yes, lowering the car causes suspension geometry to change. Purchase adjustable tension rods for best results. What are you using the car for? DD or track
blingbling is offline   Reply With Quote
Old 06-30-2011, 01:00 PM   #3
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Feedback Score: 73 reviews
Send a message via AIM to hOngsterr
yes you do need it, without it, your steering wouldn't be perfectly straight, so get adjustable tension rods.
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
hOngsterr is offline   Reply With Quote
Old 06-30-2011, 01:08 PM   #4
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Even a mild drop will require adjustable tension rods for proper alignment.
Old 06-30-2011, 01:49 PM   #5
PoorMans180SX
PoorMans180SX's Avatar
Fred, why are you getting the rubber kind?
Tension rods have zero affect on ride quality, I would highly suggest ones with spherical ends such as PSM or SPL. The steering feel and front-end predictability is vastly improved over the big squishy rubber bushing. Probably the biggest handling upgrade of all the suspension pieces.
Old 06-30-2011, 01:51 PM   #6
blingbling
blingbling's Avatar
I also recommend getting the solid arms as well. No rubber!
Old 07-01-2011, 07:14 AM   #7
Fred Allen Burge
Really? I figured with the size of the stock bushing in there they must have a lot to do with ride quality. Any time you hit a bump of any size it wants to push the wheel backwards then upwards. Isn't it this arm that prevents that backwards motion and transfers it into upwards motion through the shock and spring? I'd think a sold bushing would cause a really noticeable "hit" each time you hit any kind of expansion joint or ridge in the road.
