Longest Lasting Tires
Hey everyone,
I am eating through tires pretty fast and have observed that the very cheap tires die fast. Most of my tires do not wear out gradually. They look like they get supper gummy and fall apart in patches. I have tried the Federal 595 and have noticed that they grip much better and last longer than the some of the cheaper tires. The grip from the Federals is good enough, is there anything out there that will last longer. Thanks in advance.
BakchisMotorsports.com |
Nexen N3000...The tread-wear is 340
Where as the federal the tread-wear is 240 the higher the treadwear the less grip you have and the longer the tyre will last
of couse cheap tires will wear out poorly espacialy if u try to race on them which they were not made for...when i had a poor suspension set up i compensated for some of the lag by using really good tires...what are u doing drift or grip?
There's some cheap Federal Formza (sp?) tires that have a treadwear of 420 or 460.. something like that.. only cost about $30/ tire new. lol. Might have been a sale at super autobacs at the time (now called autotoys).
![]() Join Date: Oct 2007
I have seen nittos with 440 tread wear, those things were like rocks lol |
Thanks for the replies.
Sorry I forgot to mention that I am asking about tires for drift. I always assume everyone here is into drifting and forget about grip. My rear alignment is about one degree negative (has been ok for Adams, I run 1/4 degree more on driver side there). Toe is about an 1/8" in. Stock arms that have been hacked and extended. Anyway, appreciate the feedback and keep it coming. I am trying to stock up on tires for Horse Thief Mile this weekend.
www.SonicMotor.com
![]() Join Date: Aug 2005
Trader Rating: (113)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 113 reviews
You should try the Wanli S1088. Good tread life and grippy. The Nexen will last forever, but it's kind of on the slippery side.
Sonicmotor.com | Zach @ Sonic Motor | 626.363.9036 | [email protected]
Check out our website! ( CLICK ) |
![]() Join Date: Jun 2007
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
I have ran the Nexen N3000 and they last super long....on a pair of rear I did 6 practice laps, and 8 comp lap at Seattle and they lasted all the way to the end....and still had about 30% life left and this was in my competition car. The grip is not an issue here as long as you know how to setup your suspension to where the tires works best with your driving style. Tread-wear is just a number that the tire people rate tires on their test course.
#14 | |
![]() Join Date: Jan 2008
Trader Rating: (18)
So all those ratings (UTQG) do not cross over, say you compare the michelin and goodyear, it can not be used as a legit way to measure. They only work in same manufactures lines.
"ARE YOU ONE'EM SKID RACERS?"
![]() Join Date: Jun 2004
Trader Rating: (73)
Why do you have such a CRAZY alignment setting. It's not drifting that is killing your tires, is that crazy toe setting.
#19 |
What alignment are you guys setting? I have searched and found that in the rear for drift people are running 0-2 degrees of negative camber. People are running very different toe settings. Some are toe out a bit and some toe in as much as what I am running, 1/8". I like stability in the rear of my car, but I will try to run 0 toe.
Interesting to hear that Nexens last a while, I will try them out. Thanks again for the input!
#21 |
![]() Join Date: Nov 2007
run zero toe in the rear. set your suspension up correct, and you will have grip. oh, and out of all the tires my KA has eaten....nexens last the longest. then there are other cheap brands...if you want smoke... up the psi!
#23 |
My 595s last a while.
I used one pair for the entire ASB weekend. (save for 2 or 3 laps at the end of SUnday
#25 | |
Trader Rating: (18)
#26 |
#28 |
nexens smoke pretty nicely if you have more than 200hp. not so much with a ka.hhaaa
#29 | |
![]() you heard wrong. sorry. so sorry.
