Z Chassis Technical discussion related to the Z Chassis such as the S30, S310, Z31, Z32, Z33 and Z34. |
08-09-2011, 10:57 AM | #1 |
z32 overheating problems
Im still sorta new to this forums. been lurking for a while but hopefully im in the right place and all.
So i bought a 1990 z32 a few months ago with a bad tranny with the intensions to fix it and turn it. so i swapped the trannys out and started driving it. It was running fine. shifted kinda hard but wasnt the end of the world. A bit later i started to drive it a bit and was just doing small fixes. Then it started to overheat and i realised the radiator had a leak. seemed like it had a lot of pressure though. Got it home and swapped the radiator. filled it up and water pump was done. swapped that. started to drive it again and it seemed fine around town. then i got on the freeway and I noticed it went up. It seemed that it was really getting overly pressurised. I tried to get it home the next day on surface streets and had to stop every mile or so. seemed like it built up a lot of pressure so i pulled the thermostat last night and threw in a pot with a new one and just before boiling they both opened up. so not the thermostat. not the radiator. stock fan works. not the water pump. hoses look to be good. Idk if this helps but i put water into one of the water pipes with the thermostat out and eventually it came out the other side. So looks like it can circulate. guage is fine. So im thinking BHG but im not sure. i think ill test for that today but my oil dusnt look milky. so any help would be great. thanks for the help in advance |
08-10-2011, 06:07 PM | #2 |
I had a similar issue with my first TT..
BLEED THE COOLANT SYSTEM ..meaning, get all of the air bubble out of the system, It was a simple fix for me, hopefully it's the same for you.. If the HG was blown, you wouldn't have a radiator in the car right now
08-16-2011, 02:20 PM | #4 |
nvm. figured it out. found out the bleeder valve was taken out of my car so i lifted it and ran it and opened it up to bleed. problem solved. not sure which fixed it but its fixed and driving great now. thanks for your help
