Old 01-04-2011, 01:36 PM   #1
Russo
Russo is an unknown quantity at this point
Lean sr20det and stalling
Hey guys I'm trying to finish up my first sr20 swap in my s14. It's a s13 blacktop sr. The car runs great when it's cold but when it warms up it starts running very lean 18:1+ it idles fine until you give it gas. Even a short blip of the throttle will make it fall on it's face.
It then proceeds to shake violently until it finally dies. I'm honestly stumped with this one I've cleaned the iacv, replaced the maf and honestly don't know where to go from here.
I suppose it could be a bad fpr or something fuel related which would make sense as why I'm running lean. I also put in a walboro 255 and a 300zx tt fuel filter
Any insight from you guys would be great. I really appreciate it
Forgot to mention is seems to run better with the cts unplugged but I literally just replaced the cts with a new one
Russo is offline   Reply With Quote
Old 01-06-2011, 12:26 PM   #2
Russo
bump, nobody?
Old 01-06-2011, 12:29 PM   #3
nismoman
nismoman is an unknown quantity at this point
do you have a fuel pressure guage? and are you sure the fuel lines didnt get reversed when you hooked them up to the rail? how much voltage do you have at the pump?
nismoman is offline   Reply With Quote
Old 01-06-2011, 12:42 PM   #4
Russo
I don't have a fuel pressure gauge the fuel lines are hooked up correctly and I havent checked the voltage at the pump. Also in limp mode with mafs unplugged it runs nice and rich. if fuel pressure were an issue wouldn't this not be the case?
Old 01-06-2011, 01:46 PM   #5
Silvia716
Silvia716 is an unknown quantity at this point
It could be your o2 sensor or coil packs/spark plugs I just finished my swap and it was doing the same thing I changed my plugs and lines and she's running good now still running lean tho but I'm wating on fed x on my o2 sensor but that stopped her from cutting out
Silvia716 is offline   Reply With Quote
Old 01-06-2011, 02:32 PM   #6
Russo
it has new plugs but i'll check them maybe all the running weird messed up the plugs. The killer is this car has to be runnin in 11 days so it can get outa this house
Old 01-06-2011, 03:43 PM   #7
Silvia716
I would check the gap it should be .036
Old 01-07-2011, 06:44 PM   #8
Polked4G63t
Polked4G63t's Avatar
Polked4G63t is an unknown quantity at this point
sounds like a vacuum/boost leak to me, anyone else?
Swing by the local hardware store with $15'ish. Coupler, pvc cap, and screw-type valve stem...oh yea, windex.
Polked4G63t is offline   Reply With Quote
Old 01-08-2011, 12:55 AM   #9
Big Zee
Big Zee's Avatar
Big Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choices
Send a message via MSN to Big Zee
boost leak would't kill it right away, but it would cause the face falling.
check all your couplers like Polked4G63t suggested and your plugs, and try a different maf with someone that has a running sr and see if that helps, if it does your runnning the wrong maf, ( seen silvias with sr's not run on the sr maf and had to switch to a ka-e one to make the dammed thing run ) if that be the case get the number ont he top of the maf and try to find a maf with that code and hook it up.
is your bov vented or recric'd ? when you try to rev will it rev then stumble or fight for any kind of rev ?
last up is double check all your wiring. if it was a professional harness great, if you did it, make sure its all been soldered and shrink wrapped, all the right wires are going to the right place
Big Zee is offline   Reply With Quote
Old 01-09-2011, 12:06 PM   #10
Russo
i've checked all my couplers and they all seem tight, probably make a boost leak tester today or tomorrow
i ran the sr maf and then swapped it to a ka sohc maf same story
harness is wiring specialties
the bov is atmospheric
it revs up great, no stumbling. on it's way down it falls on it's face.
even if I don't rev it until the bov opens it still struggles
Old 01-10-2011, 01:44 AM   #11
murffy
murffy's Avatar
Trader Rating: (44)
murffy is an unknown quantity at this point
Feedback Score: 44 reviews
yup yup check all ur cuplings bro and try get a fpr it helps check if ur getting enough fuel to ur injectors
the spark plugs are very important also my sr had same problem and when i check the plugs they were for a sentra and they were the wrong heat the bk7e frm ngk do the job legit either the (ix) iridium or the copper ones which are like 2bux each at autozone or napa
gl bro
murffy is offline   Reply With Quote
Old 01-10-2011, 07:19 PM   #12
Russo
i regapped the plugs to .036 and it runs a little better, still running lean though I'm sure I have some vac leaks, got 14 inches of snow comming tomorrow so probably no progress to come soon. If any of you guys wanna check out the whole build I have a thread on preludepower
Other_ Russolude's not a Prelude don't kill me build thread. 56k=fail - Preludepower.com
let me know what you guys think.
also still looking for a reason i'm still stupid lean at idle
Old 01-16-2011, 07:35 AM   #13
Russo
alright the engine still shakes violently and searches for idle but only when the car is warm
Old 01-16-2011, 11:00 AM   #14
HYPNOTIK
HYPNOTIK's Avatar
HYPNOTIK is an unknown quantity at this point
Send a message via Yahoo to HYPNOTIK
Check all your fuses.
HYPNOTIK is offline   Reply With Quote
Old 01-16-2011, 11:17 AM   #15
coup-emonster
coup-emonster's Avatar
coup-emonster is an unknown quantity at this point
Doubt its fuses haha but check everything..what stumps me is that your saying that when you disconnect the maf..it runs good..did you get a new maf? Or used maf? Maybe its faulty..is it a stock maf? And if your positive it works..then id check the harness to see is there is anything wrong there..and finally worst case id say your ecu is the culprit..sometimes if your maf is wired wrong..a false ground could fry your ecu..trust me happend to mee when I wired a z32 maf in my rookie days haha the ecu smoked up!! Haha and smelled like the little toy trains hahahah..but yeah good luck bro hope this helps.
coup-emonster is offline   Reply With Quote
Old 01-18-2011, 05:42 PM   #16
Russo
the stock sr maf had the same effect the "new" (used) ka sohc maf the wiring harness is made by wiring specialties so thats good. Unless someone has a good sr20det maf on long island somewhere, idk lol
Old 01-18-2011, 06:00 PM   #17
sidedrifts13
sidedrifts13's Avatar
sidedrifts13 is on the path to ruinsidedrifts13 is on the path to ruin
Send a message via AIM to sidedrifts13 Send a message via Yahoo to sidedrifts13
Adjust your Tps
sidedrifts13 is offline   Reply With Quote
Old 01-21-2011, 08:33 AM   #18
WhiteNgold
WhiteNgold's Avatar
WhiteNgold is an unknown quantity at this point
stock/healthy sr has -20psi at idle.... if not then u have either a timing issue or boost/vac leak. check ALL grounds in harness especially the one from pass side fuse box. check the basics first. it dont hurt to check
WhiteNgold is offline   Reply With Quote
Old 01-22-2011, 11:37 AM   #19
Russo
it has ~20psi of vac at idle. all my grounds are good i'll recheck them today anyway i'll break out a can of carb cleaner and try again for some vac leak tests my tps is also set for .45v when thottles closed
Old 01-28-2011, 02:18 AM   #20
bakerzduhzen
bakerzduhzen is an unknown quantity at this point
place the motor at tdc and check your cams and chain location.
bakerzduhzen is offline   Reply With Quote
Old 01-29-2011, 11:38 AM   #21
Russo
i've checked and double checked that already it's right on
Old 04-18-2014, 09:36 AM   #22
gmorcos37
gmorcos37 is an unknown quantity at this point
Sorry for bumping an old thread but I am having similar issues. Did you ever figure it out?
gmorcos37 is offline   Reply With Quote
Old 04-18-2014, 11:43 PM   #23
240pimp
240pimp is an unknown quantity at this point
mine was running like crap, and we found out it was a bad coilpack. Runs great now!
93 Hatch w SR20
240pimp is offline   Reply With Quote
Old 07-05-2015, 01:35 PM   #24
CraftHell
CraftHell is an unknown quantity at this point
Anyone figure this out? im having the same issues and i read it points to not having a recirculating bov, or get a tune. motor thinks the air is there and placed the fuel and spark but when the time comes its not there and it falls on its face.. hence it will run great wide open and such but when you put the clutch in it idles down real low or even dies..
i have a new tomei fpr, idle vacuum is -20 at idle and new coil packs installed, walbro 255, tial atmospheric bov, and im having the same issues and cant figure it out..
i changed the fuel filter, plugs, coolant temp sensor, checked for leaks,.. only thing i havent looked into is the iacv and tps.. not sure.. any way to clean them without taking it apart?
CraftHell is offline   Reply With Quote
Old 08-03-2015, 10:34 AM   #25
adey
adey's Avatar
adey is an unknown quantity at this point
Bump for a user with a similar problem!
Links to the youtube video of the issue:
https://www.youtube.com/watch?v=vlDRKj5kZh4
AFs are all over the place, although it seems to lean to the lean side (har har). yet, sometimes it will go down to super rich! Maybe a pinched injector O-ring?
Checked all the vac hoses that I have (not many) and re-tightened all intake/IC/throttle piping...
checked MAF wiring, seems to be no issue. startup is strong and instant, the damn thing just won't idle!
Holding the throttle still and trying to keep constant RPMs doesn't work -- the rpms will hit whatever I'm aiming for, and then within a second the revs start to fall, even though my foot is stable on the gas.
Since the video I installed a Tomei FPR and set to about 3.3 bar, it made no difference.
Details:
1998 S13 blacktop sr20det
S15 T28 dual bb turbo
Z32 MAF
Stock Compression
Nismo 555cc injectors
Walbro 255lph fuel pump
HKS wastegate actuator
Tomei exhaust manifold
Tomei adjustable fpr (small)
adey is offline   Reply With Quote
Old 08-03-2015, 11:32 AM   #26
Kingtal0n
Kingtal0n's Avatar
Details:
Z32 MAF
Stock Compression
looks like it needs tuning. You never mentioned what ecu is in it.
If you are incapable of tuning whatever it is yourself, go back to the OEM injectors/maf/ecu first, and re-check your wideband's report.
The reason I suggest this is because the problem you see there could be any number of things, including but not limited to,
1. bad maf (probably not)
2. bad wideband (doubt it)
3. exhaust leak (unlikely)
4. air/boost leak (very unlikely, but check pre-turbo for a leak, for sure)
5. fuel pressure issue (due to regulator/pump, also unlikely)
6. injectors are not actually 550's
7. injector lag time is wrong in the computer
8. other stuff
Most of it is unlikely, however by swapping back to OEM parts and verifying the idle is back to "normal", you would eliminate most of it as potential sources, and you can focus on the real problem: the computer (or injector size)
https://tinyurl.com/turbo240
