![]() Join Date: Mar 2011
Trader Rating: (18)
![]() ![]() Feedback Score: 18 reviews
Tell me about my spark plugs
s14 sr20det.. I have had the motor sitting in my house. Pulled the plugs and they are pretty black. Not wet though, just looks like it was running rich, gap seems big and the are NGK R irridium 8's (shouldnt they be 7's?)
Thoughts? |
![]() Join Date: Aug 2011
Iridiums last longer, when they dont get drenched in fuel. They may be 0.00000001% better as the electrode is smaller, but considering their price, it is just not worth it. get grade 7 coppers, 4 for 15$ or less. The irridium version will cost at least 60$.
BTW you want to setup the gap correctly, 0.8mm or smaller should do the trick. They usually come gapped at 1.1mm . |
![]() Join Date: Feb 2012
jamg is right.
In the event of a super lean condition in which the electrode could be melted the iridium could possible break free of the plug and beat the shit out of the pistons and combustion chamber. Copper will burn up without hurting the top end. OP, you need p/n: BKR7-ES copper NGK plugs. If your mixture is right and your engine is running efficient the plug will have an ash color to it. Not to white, not to dark either. Just google some pictures to help you read the plug. |
#12 | |
![]() Join Date: Jan 2008
