ill tongue punch her fart box
![]() Join Date: Sep 2009
weak ebrake, no lock.
ive done new pads, and rotors within this last year, and properlly adjusted the ebrake cable nut. still is super weak and i cant figure out why. is there another way to adjust?\
91 s13 hatch. |
![]() Join Date: Sep 2005
Assuming you've bled correctly and the calipers are working correctly and the pads don't suck. Step on the brakes a few time then pull on the ebrake lever while brake pedal is down. adjust the ebrake nut. Then roll the car or try to spin the wheels, if on jack stands.
They should be locked now!
#6 | |
![]() Join Date: Sep 2007
Trader Rating: (25)
This is a common problem. I know mine are stretched the fuck out and won't lock up.
and i will also look into the stretched cable. is there an entire replacement i can just buy??? and ill try to do the jack stand locking thing. |
#8 | |
I've heard of this working a few times before. I think lot of people forget to properly set their brakes before adjusting the handbrake. However, sometimes this fails too. I've had this problem before and resorted to changing everything including the cables but that still didn't help. Its expensive and kinda a pain in the ass too. Save yourself some time and just get these > Project Mu Brake Pads - D1 Spec - a-spec tuning - engine performance & suspension tuning Epic lock-up. With them I probably didn't need to change my cables and rotors. Only downside is they create A SHIT LOAD of brake dust. gotta wipe the wheels down frequently to keep them from turning grey lol.
ok so i have done a little looking and testing, and my passenger side actually is locking but there is to much force built up without the other wheel locking to stop or slow down the car enough.
so i jacked up the car and found that on the little block where the cables split. when the brake is pulled they arent even with each other. the driver side the one thats not locking doesnt move at all really like its possibly stuck and the passenger moves as normal. should i replace the cable from here or both or try to free up the stuck cable if it is stuck and not streched. |
![]() Join Date: Apr 2011
If your serious about your Ebrake, than just do the Hydraulic Hand brake mod
With one of these http://www.ebay.com/itm/SICKSPEED-RE...74189d&vxp=mtr u might find a better deal for one on zilvia You just have to cut into your rear brake line, *not the ebrake cable lines
#14 | |
I wonder if the ebrake mechanism could be busted on that one side as well but I doubt it. Idk, when I did this last year I remember seeing the same thing and tried to do everything one part at a time but it turned into a goose chase and eventually everything was replaced haha.
![]() Join Date: Jul 2010
I have had exactly the same problem.
Don't bother with 33 handbrakes, hydro etc Instal Project Mu d1 Spec brake pads and Uras hand brake assistors (you can copies of them here gktech.com.au for $30, unsure what postage to USA will be- not much i imagine.) It went from not locking at all on lock, to locking in a straight line everytime, with minimal effort. |
