![]() Join Date: Jan 2008
Trader Rating: (26)
Alternative to pillowball suspension?
Long story short I have a s13 for daily. Changed some suspension pieces in the rear it rides too rough now. My teeth are about to fall out.. Looking for some alternative to pillow ball arms in the rear. Or something to help the ride comfort. Need to have adjustable arms to adjust my suspension geometry or else I would of kept my rear arms stock.
Changed/added 2nd gen fortune 500 w/ Swift 8k/6k 4k assist Battle version Traction Wicked Toe Wicked Toe brace Wicked RUCA New z32 alu uprights Dropped 1" lower Original setup is. 1st gen fortune 500 w/ fortune springs SPL tension rod SPL tie rod end Stealth tension rod brace Tanabe front sway Progress rear sway Stock rear arms
ಠ_ಠ |
![]() Join Date: Aug 2011
It is not an arm problem, it usually is a tire / dampers / springs (eventually ARB) problem. You got swift springs so you can rule them out (they may be a bit stiff though, but that is quality stuff)
I have ball/ rose joint arms and subframe PU bushes on my car. The only remaining oem bushes are the ones on the rear spindle. And my car is still livable ... yet it was not when i had lower profile tires on 18" wheels and PU bushes on adjustable arms. I had 5kg springs front / 4kg springs rear. Now i am down to 17" wheels, and 7/6kg springs. And it is better. Still could be way better with better coilovers... will change them in a year, maybe. A friend of mine uses tein monoflex. I was very surprised by the comfort they give, and yet their springs are on the stiff side. But again, he does not use low profile tyres. They arent fortune auto coilover money either ... |
Trader Rating: (26)
The worst part is I'm on my winters blizzak lm22 - 225 50 17. Planning to be on 18s this summer. Also the rears are on full soft @ dampening fronts are @ 18 clicks. Rear still feels stiffer then the front. Maybe it's just me cause its such a big change.
ಠ_ಠ |
Doesn't PBM have a line of "missle car" parts or something? Last I checked they had adjustable arms with poly bushings, but they weren't screw adjustable as they just had bunch of holes drilled to keep the costs down.
