#31 |
Hello again all. Long time no see. Today was one of those days for me that I am sure we all have had. Ever had one of those work days where you are in the garage all day, but you feel like you got not much done at all? In all reality, alot got done, but not as much as I had wanted. I decided to spend some time on the fuel lines.
I went back and forth on the idea of keeping rubber fuel lines, with barbed fitting on the rail and the FPR. At the end of the day, I decided to go with stainless braided lines due to the Sard rail coming with 6an fittings, and the Fuelab filter having -6an fittings on the ends. So then I came to the problem of how and at what point I should convert from the hardlines to the braided lines. On previous builds I cut, and double flared the hardline to convert. I have read now there are compression fitting for this job. I decided to give them a shot. Worst case would be to take them off if they do not work, then flare the old way. Will start the picture by showing what I started with.... And here is the OEM BMW FPR set up..... Here is a side by side of the OEM filter and the Fuelab..... Here is the first compression fitting I attempted to install. Keep in mind the picture does not show the finished product. I will still find a way to mount the line in the OEM bracket..... I didnt have much time to run the return line from the regulator. I actually realized that I was missing one more fitting. I need one more -6an hose union to finish the fuel return..... but will show off the lines i did have time to assemble I will post one more engine bay picture for good measure ![]() |
#34 |
I know this is a very small pointless question in the bigger scheme of the build, but does anyone have any suggestions on an oil cap that would look good in there?...... Lol
#38 |
#39 |
Another very small update for you all this past weekend. I have not been able to make a ton of good progress due to unfortunately coming down with an illness, and waiting on some packages.
I did get a Small package from Japan though. Nothing that was a huge surprise, but still took forever to get here. When I bought my swap, it came with a set of Splitfire coilpacks. I was pretty pumped as it was a surprise under the coil cover. upon inspection though, I found that one of the shit out its guts and was of no use. This left me with 5 that were still usable. there were only a couple companies that sold a single pack and cost an arm and a leg, but didnt see another option, unless I wanted to go back to 20 year old OEM coils. I also decided to take the time to put fresh NGK sparkplugs in. I went to a plug that was one step colder for future goals..... Will update again once packages start arriving this week. |
#40 |
Guest
Posts: n/a
--Deleted--
#42 |
Hello again guys. I received another package in the mail today, this time being from the great guys at Chase bays.....
![]() You might be asking, what might this be?...... I chose to purchase an item that seems to be seen as skeptical in the BMW world. I decide to purchase the entire ABS/brake booster delete from this group. A lot of people question this modification due to the effect it will have on braking performance, but Chase Bays claims to have sized the Wilwood Master cylinder just right to not have much difference in braking performance. I decided to go with this modification for the sole purpose of space needed to generate a down pipe for my swap. I also purchased the bias valve and brake lines to make it a complete package.... I also decided to weigh in the difference between the setups just for reference for anyone that may be interested. Along with the space this kit saves, and the visual appearance, It also saves around 16 pounds for those hardcore weight savings people out there.... Pictures for proof..... I have posted pictures previously of what the OEM setup looked like and how crowded it made the drivers side engine bay look. Here is a picture of what that area looks like with the OEM setup taken out. BTW, it was a [email protected]$% to lay under the dash on the interior and work to remove connections..... I got as far as I could with the install today. I came to a stopping point as the package i received from Chase Bays did not include a small bracket that it should have so that I could connect the Bias valve to the master cylinder. So I only got a chance to mount the booster delete plate and the master cylinder today. The kit i purchased also came with a new feed hose for the OEM clutch master cylinder. I decided to use the OEM feed line as it fit perfect on the bulkhead fitting i attached to the Wilwood reservoir. I also came to this conclusion due to having to remove the entire pedal assembly just to get to the clutch master cylinder. A lot of work saved just by using the OEM feed line. Anyway, here are some pictures.... |
#45 |
Another small update for you all. I finally decided to take some time to tackle the fuel pump. I knew the OEM BMW pump would not support my goals using the 1000cc injectors and planning for around 20psi. I also didn't want to do anything crazy like a standalone fuel cell.
I decided to call upon a group called Rally Road that machined and install sleeve to make many after market pumps a drop in affair. I opted to pay a little more money and got the Aeromotive 345lph. I have read these pumps can support pretty big numbers when using 93 octane. Here is what the kit came with..... I didn't get alot of picture when taking it apart, but its pretty straight forward. I was actually surprised how easy it was to remove the rear seat and gain access to the fuel pump assembly. I did take some pictures as I put it back together. I did make sure to shop vac alot of gunk that had built up on top of the assemblies. I also would like to note, I opted to connect the wiring the correct way by soldering and heat shrink the connections. You can see this if you look at the pictures close. |
#46 |
Another small update. Actually it was a large key to finishing up the build, but not alot to report. My custom driveshaft came in from Shaftmasters. I decided to go with the aluminum 3 inch variation. I was for sure a tight fit under the car but does fit. Here are a couple pictures for records. Sorry for the crappy pictures under the car. I dont have a lift at my disposal. I tried to get shots of both ends....
#48 |
Those compression fittings are meant for carbeurated setups. They don't take more than 50psi I believe. Eventually it will work it's way off and you'll have a leak. It would be better to do a 37 degree single flare with a tube nut to attach to the -6 line.
#49 |
Hello again everybody. I wanted to post real quick since i have not in a while. I am in the process of purchasing my first home. Not a whole lot has happened with the car since I last posted. I am having Saikou Michi build me a custom catch can with my build. I have alos been gathering more and more parts to complete the downpipe, Exhaust, and charge piping (thanks to Treadstone and Vibrant Performance). The car will be running a 3.5" downpipe and keep that same size all the way to the rear of the car. I also plan to utilize 3" charge pipes from turbo the intake manifold. I did take the car to my Fab guy, which it is where it sits now to get all this done. I will post updates as he sends them to me.....
I can not believe how dirty the car got over the winter in the garage. It was the first time it saw daylight since the BMW motor was pulled.... Here are the first small updates I received from my car away from home..... |
#53 |
Ok guys, Just a small update with the car in the shop still getting some fabrication work done.
While the car has been at the shop I have decided to consider some heat management around the turbo and the manifold. I picked up a PTP turbo blanket, DEI fire sleeve for the turbo oil feed, A fire sleeve from Heatshield Products to protect the -10an turbo drain, some DEI titanium wrap for the down pipe, and some DEI gold tape that I plan on placing on the turbo intake and the cold side of the charge pipes. I also have picked up some Aluminum sheath from DEI that has yet to come in, for the protection on the fuel lines. I wont bore you all with much pictures on this post. Most of the charge pipes were completed today. It is straight 3" aluminum from the turbo to the opening of the inlet manifold. I This the placement of the Tial BOV is ideal as close to the Throttle bodies as I could get. The one in the picture was just used for mock up. It was a spare the shop had laying. Mine will be in black. On a side note, I hope to pick up my Haltech ECU this next week...... Cheers until next time.... ![]() |
#55 |
I just got done reading through your progress posts. Very entertaining. Certainly a cool different rwd chassis with a Nissan drivetrain than most are used to around these forums. I am a fan!
#57 | |
My favourite engine in one of my favourite chassis. Love it.
Sent from my E6653 using Tapatalk
#58 | |
Also this is the exact turbo Raw Brokerage sells with their bolt on turbo kit on all the Rb motors. |
#59 |
Bought my Haltech platinum pro ecu today. Sad times. Talk about hurting your bank accounts feelings. Hal here local at a very reputable shop called Dynosty (will be doing the tuning) said I picked up the last one on the current batch coming over from the land of the Kangaroos. Should be here in about two weeks.
#60 |
Just a small update. I know I posted already today, but just got an update from my fabrication guy. He was able to totally finish up the charge pipes. He sent me some pictures of the lower portion of them that attach to the intercooler. Just thought I would share.
And an update on the downpipe. Last edited by dcreech0; 05-13-2016 at 04:26 PM.. |
