![]() Join Date: Apr 2007
S-Chassis ducting thread
hey guy's i'm going to be doing some ducting over the winter on the 2jz coupe.
I was just looking for some ideas as to how or what you did to your car's and if the car runs and cooler? what would be the best material to use? just a thin piece of sheet metal or some sort of thin aluminum sheet. here are a few pic's I've found through doing some searching. please post your setups or techniques.
It would be easier to help you if you posted a less vague description rather than just "ducting". What are you looking to run the ducting to, brakes, engine compartment, a fluid cooler (oil, ps, etc.). Not trying to be an ass, but just a thought.
As far as brakes, you can run a naca duct in the bumper, weld a piece tubing to the dust shield, and connect the duct to the tubing with some high-temp hose. Check out Pegasus Auto Racing Supplies - Home Page for the ducts and hosing. For the engine compartment there's always a hood scoop, though it can look like crap if not done right, or the more extreme like the s13 that you have pictured. And there is always the hood lift mod, where you space up the back of the hood from the hinges, but too me that just makes the hood look like it doesn't fit right. And the s14 that you pictured is a making a front splitter which is more of an aerodynamic upgrade. Again I don't mean to, or want to, sound like an ass, but just saying. |
![]() Join Date: Sep 2006
i agree it would help if you stated what is it that you are trying to duct air to... however thank you so far for your initial contributions, some of those pictures are sexy.
& yes front splitters have more of an aerodynamic aspect w/ the whole low/high air pressure blah blah, but they would also help cooling capabilities of the radiator/oil coolers/ etc much in the same way that those 'radiator panels' do. 2 benefits in one upgrade. yay. |
i geuss i made the thread for any kind of ducting that s-chassis guy's do.
the ducting i am looking for is more-less for cooling of the radiator/oil/trans coolers. also from what i remember the Green S14 splitter is used for cooling.
![]() Join Date: Sep 2007
bump
i want to see some more ducting stuff. preferably on s13's with pig noses
1989 Nissan 240sx - Hatch - Sr 2006 Honda Ruckus - Fat & Low |
i know there are a lot of ingenious folks on zilvia so im disappointed no one else has contributed. i just found this, in regards to brake cooling. its a mustang, but its the same principle. DIY Brake Cooling Duct Fabrication - MustangForums.com
i also found these awesome write ups that i think everyone in the world should read! Undertrays, spoilers & vents pt 1 Undertrays, spoilers & vents pt 2 Undertrays, spoilers & vents pt 3 efficient radiator shroud tips Last edited by dawagarage; 07-22-2010 at 08:17 PM.. Reason: additional information |
Id like to see a write up on that S14. Im having overheating problems and would like to make my own panels underneath the car. I would like to know what material you used, how you mounted it, etc..thanks
![]() Join Date: Jan 2011
set the example....just use ideas from other platforms
still a car... |
#12 | |
![]() Join Date: Dec 2004
Trader Rating: (58)
No reason a stock setup should be overheating like you're saying.
![]() Join Date: Jul 2009
I had to do something similar to that green senior when I had my sr due to the fmic being out too far. Piece of aluminum sheet metal hidden under the car connecting the underside of the fmic to the core support. Prolly do the same with the 2j between the core support and the bumper if it shows signs of running hot
