![]() Join Date: Feb 2003
Car not starting anymore... what could it be?
So my s13 with redtop sr20 doesn't start anymore... heres the story... This is the 2nd car I had the motor in, 1st car blew the headgasket, had a trusted shop change it. Swapped it into new chassis, ran fine after that except ran VERY rich because it wasnt tuned for 550's so I rarely drove it. The car then sat for a month until I got a enthalpy tuned ecu. The day I put the ECU in it started up and ran fine, but i didnt get to drive it since i was in the middle of a q45 brake upgrade. I got a beater car, and was busy and the car sat for another couple weeks, in that time the battery died from the stupid factory alarm. I ripped all that junk out and jumped the car and now when I try to start it it just cranks forever and doesnt start.
The car has spark, the ignitor chip is fine. All the fuses are fine. Checked the injectors and they pulse. There is fuel in the rail. The spark plugs dont smell like gas at all. Compression is decent 150 across the cylinders. I just cant seem to figure this out and i'm totally out of ideas. The car has- hks cams step2 greddy valve springs apexi headgasket stock thickness gt2871r .64 #24 topfeed injectors on custom rail z32 mafs walbro pump enthalpy tuned ecu for cams/turbo/z32maf/injectors and a bunch of other stuff that isnt relavent to my problem if you guys have ANY ideas please post them i'm willing to try anything!
WRECKED. |
![]() Join Date: Nov 2007
you do have second starter wire. it probably goes to the alarm what you probably need to do is to jump the stater wire at the harness where the alarm was pluged into. when you took out the alarm you left an open circuit.
