Low oil pressure hot lapping, oil cooler setup recommendations
So recently went to a drift event a week ago and at a point saw my oil pressure gauge hanging around the 8-9psi mark after hot lapping a few times coolant temps were 185-190F so not crazy hot. I let the car cool down and parked it for a while. Didn't make any noises or anything like that.
Im running an AEM oil pressure gauge so it isn't really a cheap gauge and it's pretty accurate. So I'm wondering if #1 my oil pump is starting to go out, the engine is pretty freshly rebuilt (maybe 5-6k miles on it) but the oil pump was re-used but the engine was mint and really low miles before refreshing the engine anyway. #2 the gauge sensor might be a little off but i doubt it, the gauge/sensor isn't that old or #3 i need an oil cooler. It's a redtop SR, S14 T28 at 10psi, 550cc injectors, z32 maf. any suggestions or help would be appreciated also i want to get an oil cooler anyway, if anyone has any bolt on oil cooler suggestions it'd be appreciated
If I had a dollar for every pet named "nismo" by a nissan owner Id be rich |
![]() Join Date: May 2019
Before anything, confirm true oil pressure with a good mechanic oil pressure gauge. And what oil temps are you getting?
If it is true low oil pressure, could.be few issuses...improper tolerances on the rebuild, failing oil pump would be main conern. What oil weight are u running? |
Who do you actually know that's had an oil pump fail?
I'm sure it's possible... You're asking if your temps are related to the pressures, so, you obviously need to figure out the temps and think about oil weights, if you think the pump was installed right. |
![]() Join Date: Mar 2008
Did the oil pressure have better readings after the engine cooled off?
I think it's crazy some of you SR guys don't run an oil cooler. Do they even have a heat exchanger? High rev's, an aluminum block and the little screaming t2 turbo's will heat the oil up very quickly. Spun rod bearing seem to always plague the SR's after a hard track day which makes me wonder what the oil temps are. For the cooler, I'd go big. I installed one of these on my KA-T and my oil temps went from 125*C to 85*C. It's massive and barely fits in the area where the windshield washer reservoir used to be. I don't run a thermostat as it's not really needed in Socal imo. ![]() |
Ive seen multiple oil pumps fail btw. Just tryn to help the op thats all |
#6 | |
yea i can do that, and i don't think it's an issue with the tolerances on the rebuild because if that were the case i would have had issues with oil pressure from the get-go. It's been something i've noticed recently but not in the past. Also im running 15w40 but only because im in TX gets pretty hot over here.
I had a buddy that also runs an SR his oil pump died on him in the middle of a sweeper (this summer) had his gopro on and his gauge ended up reading 0 after a while and he caught it too late. Oil pumps are mechanically driven but it is a part that can fail i don't know why ppl assume they never fail even if you never seen one fail lol i don't have an oil temp gauge only oil pressure but i'd imagine maybe temps got high enough to thin out the oil to cause the pressure to drop to 8-9psi that is IF the oil pump isn't going out
#8 | |
#9 | |
https://www.amazon.com/Tru-Cool-L7B-...99912833&psc=1 |
#10 | |
#11 | |
![]() Last edited by spooled240; 12-29-2019 at 11:36 PM.. |
#12 | |
![]() Join Date: May 2009
I would purchase accusump oil accumulator and mishimoto oil cooler. This is the best setup for under 500 dollars and gives you a piece of mind.
https://www.cantonracingproducts.com...cumulator.html https://www.mishimoto.com/automotive...html?limit=all |
#15 | |
(except for specific engines - doubt you have a 5.4 in a 240 - any engine with such a problem obviously shouldn't be used, at least without retrofit and knowledge of the problem) I know SR's may have some oiling problems, I don't work on them, but that's still ridiculous. |
#16 | |
#17 | |
Anything is possible, but it still didn't happen. |
well in his situation after the engine was out he had a shop diag it and they said the oil pump failed, machined a new block, new oil pump, water pump etc and he was good to go. Not sure why you don't believe oil pumps can fail or if you're trolling but oil pumps can go bad, and usually before they do you gradually start to lose pressure before they go out. Also had another buddy start to notice he was getting lower and lower oil pressure on cold starts (started seeing 20psi ) when cold he eventually pulled the engine changed out his oil pump and that solved his problem before it got worse. We talked about it because I was trying to diag a similar issue years back.
#19 | |
Again, it can. It's just about the rarest engine part to fail - a sender is much more common, as is some other failure or wear that causes pressure issues, and even does cause pump damage or contamination that would be the end of diagnosis for many people (like, apparently, you), who would declare it to be yet another mysteriously bad oil pump. |
#20 | |
Op asked for help, not for sumone who has to prove his point(which he is wrong about) to help solve an issuse. Oil pumps fail...EVERY MENCHANICAL MOVING COMPONENT has a life span. Basic friction, and wear will eventually cause a pump to fail. But by all means if u so have to PROVE your point, pay the op to ship his motor to you. Tear it down, pay to have the metal checked, oil content checked and come back with ur findings. And please rub it in all our faces. |
#21 | |
You reverted to the "every part fails" logical fallacy. Sure, they do, absolutely dead last, no matter what lazy shop told some bros it was their oil pump. He asked about hot oil pressure. I said find out how hot the oil is, you said "it's your oil pump brah ". |
#22 | |
Not full of shit.....just cause u havent seen it doesnt mean its never happend. And apprently u cant read.....look over my first post again before u say something...i gave suggestions. But ur here tryn to state facts when ur wrong brah ![]() |
#23 | |
On top of that in my post i never said it was what i thought failed but a possibility hence why i want to get an oil cooler to see if that helps (which im sure it will)
#27 |
very annoying
#28 | |
exactly why i was leaning more towards getting an oil cooler first just to see if that remedies the issue, however the coolant temps weren't crazy high so it made me think otherwise. Going to try and get a oil cooler kit real soon
#29 |
That i have not, but is that more of a "band-aid" type of fix?
