Rb26dett awd oil pan- rwd conversion
Thought I would share some work I have been doing. I took the pic's off my phone so its not the best of quality but you should be able to understand.
I dont want to spend an hour on here explaining so if you have questions , ask. First off make sure you take out the lsd , shaft, etc. then make your marks, take your time cutting so you dont make a stupid mistake. |
Haha, I've had to do that same job before when I put an RB25 Neo into my old coupe. So much aluminum dust everywhere.
Yours turned out very nice!
Brendan : Union Autoclub '90 Coupe - RB25 Beater | '72 510 - SR20 Project |
![]() Join Date: Aug 2006
so i just finished doing this exact same thing to my neo rb25 oil pan and have a question.
i cut the diff off and the oppisite side flange off. can i leave the hollow tube in on the inside that the shaft used to go in rather than welding the holes shut on the outside? it should still keep oil from leaking....right? since i am putting this pan back on the original motor i cant see why it would be a problem. |
Weld it or tap it and plug it...
My SR20VET |
![]() Join Date: Jan 2010
bumping this up, why because i might have to do this soon!!
