03-30-2008, 10:20 PM | #1 |
Trader Rating: (37)
Feedback Score: 37 reviews
need help changing fuse for gauge cluster
guys dont hate. lol some people tell me its easy to change but can someone tell me how to change it. some pics would help if you got anytime mine just went out 3 days ago. the light just stopped working. ty for your time
Touke <3 |
03-30-2008, 10:30 PM | #2 |
Trader Rating: (106)
Feedback Score: 106 reviews
Are you serious??? Just pull the old blown one out either with needle nose pliers or a fuse puller and plug the new one in! Pretty self-explanatory.
03-31-2008, 01:42 AM | #3 |
are you sure its a fuse, and not a light bulb that blew? if you swap out the fuse and it doesnt fix anything, check out your lights in the gauge cluster.
read the cover on the fuse box under the dash and look for the one thats labeled for the gauge cluster.
|OO\____/OO| Okinawa JP 2003-2006 Currently: R14 -- Carolina Nissans Elite |
03-31-2008, 03:11 AM | #5 |
Banned from the Marketplace
Taking the cluster out?
It's pretty easy. Unbolt the under column cover thing, drop the steering rack, unscrew and take off the gauge bezel, then unscrew the gauge cluster and pull it out. |
03-31-2008, 03:24 AM | #6 | |
Trader Rating: (37)
ima take it out in school tomorrow.
Touke <3 |
03-31-2008, 10:09 AM | #8 |
Drop the steering RACK??? Are you smoking something??? All you need to do is remove the lower panel (above the driver's knees), the column cover (covers the switches on the column), un-bolt the steering column and drop it down (4 12mm bolts/nuts), remove the guage cluster bezel, and remove the cluster itself. Everything is either a 10mm bolt, 12mm nut/bolt, or a phillips head screw. Do everything in the order mentioned above and you will have no problems.
03-31-2008, 10:14 AM | #9 | |
08-22-2008, 03:50 PM | #14 |
i have a problem as well with my cluster
the tail light fuse blow so i replaced it with a new one but it only stayed on for like a minute then it blow so whats wrong |
08-22-2008, 05:59 PM | #15 |
this reminds me of my buddy daves 240. he doesn't have much of his interior or lower kick panels. there a little white box under the fuse panel sorta. his gauge cluster went out. radio. int. lights and some other things went out. he couldn't figure it out. none of his fuses were blown. he kicked this box by accident and it would flicker on an off. he tried switching the box with one of the other 4 240s around. bam. fixed everything.
so keep that in mind if your fuses are still good. and I find it hard to believe that ALL the bulbs in the cluster blew and I think your wasting your time pulling the cluster |
