Old 08-14-2007, 12:05 AM   #1
colombian240sx
colombian240sx has made poor choicescolombian240sx has made poor choicescolombian240sx has made poor choicescolombian240sx has made poor choicescolombian240sx has made poor choicescolombian240sx has made poor choicescolombian240sx has made poor choicescolombian240sx has made poor choices
whats the best way to install wide rear fenders???
well guys im about to put my rear wheels that are 11.5 wide, and thats why i have to install my rear wide fenders, but i don't know whats the best way to do it, so if you know whats the best way, or you have any suggestions please lend me know.
thanks.
colombian240sx is offline   Reply With Quote
Old 08-14-2007, 12:13 AM   #2
RPS13FREAK
RPS13FREAK has a spectacular aura aboutRPS13FREAK has a spectacular aura aboutRPS13FREAK has a spectacular aura aboutRPS13FREAK has a spectacular aura aboutRPS13FREAK has a spectacular aura aboutRPS13FREAK has a spectacular aura about
19.5 inches WIDE?! WHOA
SHIFT_zilvia
RPS13FREAK is offline   Reply With Quote
Old 08-14-2007, 12:20 AM   #3
Phoenix_95
Phoenix_95's Avatar
Phoenix_95 will become famous soon enoughPhoenix_95 will become famous soon enoughPhoenix_95 will become famous soon enoughPhoenix_95 will become famous soon enoughPhoenix_95 will become famous soon enough
Wurd...you much have gotten those from A Spec lol. Thats like 18 feet worth of lip
Phoenix_95 is offline   Reply With Quote
Old 08-14-2007, 12:20 AM   #4
colombian240sx
jejeje i typed it wrong sorry!
Old 08-14-2007, 12:22 AM   #5
colombian240sx
the wide its 11.5
Old 08-14-2007, 12:33 AM   #6
Phoenix_95
Phoenix_95's Avatar
Well, there are several FAQs on zilvia from various other people that went widebody. If you just search for them...I know there is at least 1 that is VERY in depth and should be able to answer every question that you might have. Also, if you haven't done bodywork before you might should take it to a bodyshop. Just to avoid the whole "Oh shit, what have I done to my car?!" speech.
Old 08-14-2007, 12:55 AM   #7
Matej
Rivets look the coolest.
Old 08-14-2007, 12:57 AM   #8
Dousan_PG
Dousan_PG's Avatar
Dousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfection
wide fendres are easy
welder
plasma cutter
rivet gun and propane torch and hammer is about all you need
takes a few hours to do it right
i want to mold my rear wides in
looks sooo fucking awesome when its smooth amd molded
but alas, no cash
and it will crack due to regular track events.
Aaron
Pink GodziRa
www.geocities.com/pink_godzira
Dousan_PG is offline   Reply With Quote
Old 08-14-2007, 02:12 AM   #9
3-240's-N-aMule
3-240's-N-aMule's Avatar
3-240's-N-aMule is a jewel in the rough3-240's-N-aMule is a jewel in the rough3-240's-N-aMule is a jewel in the rough3-240's-N-aMule is a jewel in the rough3-240's-N-aMule is a jewel in the rough3-240's-N-aMule is a jewel in the rough3-240's-N-aMule is a jewel in the rough3-240's-N-aMule is a jewel in the rough
Here ya go my good man. Dont know if i can post a walk through from other 240 sites but o well! Complete rear widebody install.
http://nismokc.com/forums/viewtopic.php?t=3483
3-240's-N-aMule is offline   Reply With Quote
Old 08-14-2007, 09:23 AM   #10
fromxtor
fromxtor's Avatar
fromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfection
Send a message via AIM to fromxtor Send a message via Yahoo to fromxtor
^^ Thats a good write up...but this picture scares me. I don't like the possibility of the extra fender skin cutting into a tire.
Seller feedback>>#/f/showthread.p...light=fromxtor
fromxtor is offline   Reply With Quote
Old 08-14-2007, 10:23 AM   #11
colombian240sx
thanks guy it was a lot of help!!!!
Esteban.
Old 08-14-2007, 11:29 AM   #12
Dousan_PG
Dousan_PG's Avatar
ugh nice write up
but you cut those fenders waaay too low
i cut mine like at least 1+ inch ABOVE the body line
Aaron
Pink GodziRa
Old 08-15-2007, 03:18 AM   #13
3-240's-N-aMule
Originally Posted by Dousan_PG View Post
ugh nice write up
I figure if u cut too much of the rear away, you lose a good bit of structural integrity in the rear which would make the ass of it more flimsy and flexible. Also i dont think you could slam it that low if you're runnin correct size wheels (18inch and larger and hella wide) on widebody to warrant a reason for cutting so far up. Unless you run over an elephant and you dont have coils, you're wheel shouldnt travel that high and outwards to slice your tire. I could be wrong though.
Old 08-15-2007, 03:57 AM   #14
atom
atom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to all
In that writeup the guy did cut above the body line? He just cut it real low at first to split the panels then riveted the inner panel up higher, then lastly he chopped the rest off. 10th pic down you can see he chopped the rest of it off after riveting.
atom is offline   Reply With Quote
Old 08-15-2007, 11:23 AM   #15
Dousan_PG
Dousan_PG's Avatar
yes you are wrong
haha
shit NEEDS to be wide and low
WIDE AND LOW
18" wheels . 245 tires
soft rear suspension, mega grip minimal camber.
gotta cut above that line. u can see how much it tucks under this compression.
flimsly? how so? its not the chassis, its thin metal. its not structural at all.
dont fool yourself.
but i guess if u dont do track events and stuff, then meh. whatever.
Aaron
Pink GodziRa
Old 08-15-2007, 11:56 AM   #16
hellion240sx
dousan, i'm surprised you didn't have the tire going inside your car? what are you running? awesome pic btw.
Old 08-15-2007, 11:58 AM   #17
Dousan_PG
Dousan_PG's Avatar
suspenion? stance GR+ 7kg rear
fenders are origin 30mm
work done by me and lindsay
mig welder
hammer
time
plasma cutter
propane torch
and rivits and drill
thats all u need
Aaron
Pink GodziRa
Old 08-18-2007, 03:12 AM   #18
Behind Horizon
Behind Horizon will become famous soon enoughBehind Horizon will become famous soon enoughBehind Horizon will become famous soon enoughBehind Horizon will become famous soon enough
I'm going to cut my old rear fenders and going widebody in the next few days also. However it would be nice if someone could post some pictures of a S13 hatch where this job had been done properly. I'm especially looking after pictures of the cutting job, as i don't know how high i should cut. Thanks in advance.
Behind Horizon is offline   Reply With Quote
Old 08-18-2007, 09:39 AM   #19
Bushido
Bushido's Avatar
1 inch above the body line.
Old 08-18-2007, 01:50 PM   #20
Behind Horizon
Sorry but i can't imagine where the "body line" is located.
Not my car but i think it is still too low ?
Old 08-18-2007, 01:55 PM   #21
ThatGuy
Admin Asshole
ThatGuy's Avatar
See the line running through the middle of the gas cap?
The "line" on the "body"?
Yeah, that one. That's the "body line".
Old 08-18-2007, 02:30 PM   #22
Behind Horizon
Alright as we all know what the body line is now i think that 1" above the body line is be a bit too high? I think if i'll cut up to that body line it should be enough space, or am i wrong ?
Old 08-18-2007, 02:37 PM   #23
OptionZero
OptionZero's Avatar
OptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfection
Send a message via AIM to OptionZero
read the thread again
it is not too high
OptionZero is offline   Reply With Quote
Old 08-18-2007, 03:46 PM   #24
Matej
Don't worry, you can go way higher than that, you can pretty much cut off almost the entire panel as long as you leave enough to attach the overfender to. Less quarter panel = less metal to rust, haha.
Old 08-20-2007, 01:13 AM   #25
Dousan_PG
Dousan_PG's Avatar
dont ask if you wont take the advice
1" above
no less
more is ok
Aaron
Pink GodziRa
Old 08-20-2007, 06:41 AM   #26
Behind Horizon
1" above
no less
more is ok
Why i wouldn't take advice, i already cut my fender now and i think i cut 2" above. Thanks for the help guys.
Old 08-20-2007, 01:30 PM   #27
seiyess
seiyess's Avatar
seiyess will become famous soon enoughseiyess will become famous soon enoughseiyess will become famous soon enough
Send a message via AIM to seiyess
yeah~ cut it up as much as you want!!
it's all thin metal anyways.
i think it depends on what kind of looks and set up u want.
rough rugged battle look ----> rivets!
smooth clean look----> cover them with filler, bondo and all the good stuff.
and i would say cut the fender as much as you can. then you can go low as you want if you want it lower after. you are going to cover it with wider fenders anyways.
seiyess is offline   Reply With Quote
Old 08-21-2007, 01:52 AM   #28
Behind Horizon
Thats how we did it, the fenders will be cleaned, primed and sprayed soon also, i think i wouln't cut any higher, maybe i would cut 1/2inch lower next time:
Old 08-21-2007, 05:40 AM   #29
420sx
420sx's Avatar
420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future
that actually looks pretty clean. im guessing u tacked the skin and the cut off the rest.
did u seam weld just the rear wheel well or you got everything else too?
hydropgrahics!
ls1......
420sx is offline   Reply With Quote
Old 08-21-2007, 12:49 PM   #30
Behind Horizon
Yeah i seam welded the rear arches from the inside, i also drilled holes and then spot welded it where it is possible.
