![]() Join Date: Sep 2002
Location: Athens/Chattanooga/ Cookeville/Morristown, TN
Q45 brakes
how beneficial are they, ive searched already, but didnt really get a clear answer if there were any detriments to getting the Q45 front brakes on an s13...? anybody have them? i know they're a direct bolt-on and all..
89 240 SR powered... ummm i promise its stock
![]() Join Date: Oct 2001
[email protected] has them on his S14, and considering the Q45 was a huge heavy car they brakes prolly work good on a light s13, goodluck!!
Junkie
![]() Join Date: May 2002
Phase2Motortrend.com is selling the q45 kit right now and this is what they had to say about it....
"Traditionally most people went with the Z32 brake route because it's easier to find in junk yards and more popular approach. However, most people with the Z32 brakes generally agrees that the Z brakes tends to act like an on/off switch where when one heavily press the brake pedal, front wheels gets locked up too quick. The Q45 brake calipers selected by Nismo tends to avoid this type of problem, gives user a more definite feel of brake pedal feel where the driver has the ability to modulate the brake pedal to slow down the car without chances of locking up the front wheels too fast." You can probably piece together your own q45 kit for a little cheaper but your bigest problem would probably be finding someone to redrill rotors to 4 lug. I found the rotors and calipers at a part store for $230 upfront ($170 after I brought them back my calipers as core charge) and depending on the pads you buy it might be around $60 more. THEN!, if you want to go all out you can get some Stainles Steel lines all around and get some better brake fluid. Of course it costs a little over $100 more. As for performance value, MAN do they ever help. I might have mentioned it before but the only thing hindering my stopping power now are my tires. Yes, you can lock up the tires, but you can also finesse the brakes to control a steady stop. Very good investment in my book.
-Juan |
![]() Join Date: Sep 2003
#6 | |
from Canada, eh!
![]() Join Date: Sep 2001
Did you change the master cylinder and the rear brakes? Do you have ABS?
-> HaLo Race Car: '98 E36 BMW M3 Daily Driver: '08 Fiji Blue Honda Civic Si SOLD: 01 GPW Honda S2000 PARTED: 93 Pearl White 240SX LE Fastback w/SR20DET SOLD: 93 Super White 240SX SE Convertible w/Silvia Front |
#8 | |
#9 | |
Junkie
Q45 front rotors and calipers Russel SS brake lines Motul 5.1 brake fluid All this was a little over $300 after I got my core deposit back. I knew someone with access to a drill press so I got the rotors redrilled for free. I did find a place that would redrill the rotors also but they were charging $70, which was more than I paid for the rotors themselves. No ABS on my 240.
-Juan |
Junkie
No it doesn't. Like I mentioned before...it really leaves it up to you whether you want to lock up the wheels by stomping out the brake pedal OR coming to a steady stop as usual. Pedal feel is exactly like stock if not a little firmer with the SS lines but overall you might not notice the difference in pedal feel, only stopping power.
-Juan |
#13 | |
Junkie
I just mention that you can lock up the brakes just to show they do have power.
-Juan |
![]() Join Date: Jan 2003
I have 30mm aluminum z32 fronts with stock rears, metal pads all around, stainless lines all around, motul 5.1 fluid, 5 lug conversion, speed bleeders and 1" Z32 M/C.
I have yet to lock up my front tires, even under very hard braking at the Willow Springs big track. And I only have 205mm R compounds up front too. Dunno. |
Junkie
Those tires have more grip and are less likely to break loose than regular street tires, that's why you probably haven't been able to lock them up.
-Juan |
#16 | |
#17 |
Junkie
No, not everyone upgrades tires and especially not to R compound tires (for everyday use that is). R compound tires are recomended for track use only, but for everyday use (street tires) that's where locking up tires becomes our issue.
-Juan |
from Canada, eh!
ACtually, I got the upgrade for track usage. I don't want my brake balance to be all f*cked up. I will be running some R compounds on the track.
What pads are you running on the Q45 upgrade? I'm thinking about EBC greenstuff...
#19 |
Junkie
Since I have yet to get myself to an auto-x event, I just use Raybestos ceramic brakes. They're good for what I do, which is just spirited driving on open highways.
-Juan |
#21 |
so the front brakes are a direct bolt on for the Q45 to the s13 and will fit under the wheels right?
also, are the rear brakes a direct bolt up and also do they fit under the stock wheels? thanks |
#22 | |
New Title
![]() If a brake system can't lock up the tires then chances are it is not capable of braking at the limit of your tires. F1 brakes lock But they have the control (most of the time) to not lock them up and brake at the limit.I wouldn't have confidence in a brake setup that couldn't lock the tires or engage ABS if you're so equipped.
#25 |
Do q45 brakes bolt directly to the s14? and what type of SS line do you need? Also, aside from not locking up...are the q45 brakes better than z32 or worse (some specs would be nice)?
Oh...one more thing, is it a good idea to get q45 rear brakes to compliment the fronts? |
#26 |
Ok. Now, I know with the 300zx brakes, you need to get special stainless brake lines. The fitting to the caliper is different than stock 240sx brakes.
Do the Q45 take the same brake lines? i've got stainless on all 4-corners of my s14, and I'd LOVE to not have to replace them to get bigger brakes. |
#29 |
![]() Join Date: Dec 2003
Still no-one has givin us an offset.....Will it fit under stock wheels?
And this is gonna sound stupid but are the Q45's allready 5 lug? I know most Nissan trucks are 6 lug so I was just wondering...... -Jeff |
#30 | ||
Junkie
You'll be fine just using the q45 front brakes. Using the q45 rear brakes will make the pedal mushy and you'll want to upgrade the MC. Quote:
The q45 rotors are 5 lug so unless your 240 is 5 lug you will have to redrill to the 4 lug pattern.
-Juan |
