Old 06-10-2004, 08:47 AM   #1
importnut
importnut's Avatar
importnut is an unknown quantity at this point
B&M Short Shifter Install
I put together a quick instructional article for the installation of B&M's short shifter for the 240.
Most of my thoughts are in the article. Enjoy!
-Alex S.
"What about the twinkie?"
importnut is offline   Reply With Quote
Old 06-10-2004, 09:08 AM   #2
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
Nice write-up! You should add two things:
**While you have the stock shifter out, you might as well replace the gear oil. Simply use the end of a 1/2" breaker bar to loosen the drain bolt from the tranny and let the fluid spill out. After it stops dripping, put the bolt back and fill the tranny from the top (5-1/8 pints, or roughly 2.5 quarts). Once you're done with this, install the shifter.**
**Tightening the two bolts from the bottom is quite difficult. The best method is to buy a set of ratcheting box-end wrenches and tighten with those as you can only get a few degrees on each turn of the wrench. Be prepared to have messy hands when finished!**
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 06-10-2004, 09:55 AM   #3
95Blue240sx
95Blue240sx's Avatar
95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection
when i did my install i had no problems with using a regular open end to get all of the bolts. when you tighten them it might be easier to use a stubby wrench. just a heads up.
Please leave me feedback
95Blue240sx is offline   Reply With Quote
Old 06-10-2004, 09:56 AM   #4
russian
russian's Avatar
russian is an unknown quantity at this point
Send a message via AIM to russian
ok ,
a little critisism. you gonna have to specify HOW to remove the bolts on the tranny that are under the firewall. they are a bitch to get too, especially if you dont have real skinny arms. under the car didnt work that great either.
one thing can be done, you can drill holes in firewall in circles with a good drill then knock it all out into 2 holes (can also be cleaned up with a grinder nicely)
then when your done with shifter, lay 2 layers of Dynomat over it. i got it for like 10 bucks at a stereo shop just ask them for some pieces they have might get some free.
it took me 15 min to install everything including drilling. if you have skinny hands it could be avoided.
I must break you.
russian is offline   Reply With Quote
Old 06-10-2004, 11:19 AM   #5
uiuc240
uiuc240's Avatar
Yeah, those are the bolts you just need to use a ratcheting wrench with. You just slap the 10mm wrench on there and click away until it's loose. Takes like 2 mins per.
Eric
2002 Mazda Protege5
Old 06-10-2004, 12:04 PM   #6
DuffMan
DuffMan's Avatar
DuffMan is an unknown quantity at this point
Send a message via Yahoo to DuffMan
12mm
Hey, importnut, come to the chicago meet this sunday
DuffMan is offline   Reply With Quote
Old 06-10-2004, 12:20 PM   #7
importnut
importnut's Avatar
uiuc240:
Thanks for the suggestion. I'll add it to the page and give you credit for it. I didn't think to change my fluid, simply because I can't get the drain bolt out (stupid 206k frozen bolts) I changed the oil in my tranny when I did my clutch...by let it drain out the tailshaft before I put it back in the car
As far as the two front bolts, I'm not a tiny guy. I was able to use a normal box wrench to do the task. I do like the idea of drilling the holes and covering with dynamat. Very good suggestion. You should also try to hit it with some paint to keep it from rusting (Something I have to worry about here in Indiana). I'll add the idea to the page and give you credit as well.
-Alex S.
Old 06-10-2004, 12:21 PM   #8
importnut
importnut's Avatar
Originally Posted by DuffMan
12mm
Do you have some info for the meet?
Old 06-10-2004, 12:45 PM   #9
DuffMan
DuffMan's Avatar
yep, #/f/showthread.php?t=52877
Old 06-10-2004, 01:12 PM   #10
link240
link240 is an unknown quantity at this point
Does it ever fall out of gear? The reason i ask is because i was driving my friends 93 civic HB with B&M short shifter. Everytime i took my foot off the gas the car would fall out of gear.
link240 is offline   Reply With Quote
Old 06-10-2004, 01:21 PM   #11
importnut
importnut's Avatar
Uh, I have a '94 civic hatchback, and my old '95 civic coupe...both had the same B&M. Never once did it fall out of gear. There is something wrong with that transmission.
To answer your question, no, the shifter does not pop out of gear.
-Alex
Old 06-10-2004, 04:35 PM   #12
importnut
importnut's Avatar
Awesome! I'll do my best to be there!
-Alex
Old 06-11-2004, 07:38 AM   #13
uiuc240
uiuc240's Avatar
uiuc240:
-Alex S.
Thanks, man! I checked your updated page Yeah, I'm not a tiny guy either. The ratcheting box end wrench helped out a ton. Everyone should have a set of those in their tool collection.
Too bad I'm going to miss the meet! Argh! Oh well, I'll be in Cali!
Eric
2002 Mazda Protege5
Old 02-13-2005, 10:41 PM   #14
whooha1217
whooha1217's Avatar
whooha1217 is a glorious beacon of lightwhooha1217 is a glorious beacon of lightwhooha1217 is a glorious beacon of lightwhooha1217 is a glorious beacon of lightwhooha1217 is a glorious beacon of lightwhooha1217 is a glorious beacon of lightwhooha1217 is a glorious beacon of lightwhooha1217 is a glorious beacon of lightwhooha1217 is a glorious beacon of lightwhooha1217 is a glorious beacon of lightwhooha1217 is a glorious beacon of light
Send a message via AIM to whooha1217 Send a message via MSN to whooha1217
i have a question, how did u remove the shifter plate? my shifter plate is sealed on there really tie... just wondering how did u guys remove it?
Nicely Moded S14 For sale
whooha1217 is offline   Reply With Quote
Old 02-13-2005, 10:57 PM   #15
kandyflip445
kandyflip445's Avatar
kandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfectionkandyflip445 is close to perfection
Send a message via AIM to kandyflip445
Screwdriver or something of the like to break the seal. Then just pull really hard. You could have made a new thread for it.
My 240 vBgarage
kandyflip445 is offline   Reply With Quote
Old 04-06-2008, 02:39 PM   #16
spooledyou33
spooledyou33 is a jewel in the roughspooledyou33 is a jewel in the roughspooledyou33 is a jewel in the roughspooledyou33 is a jewel in the roughspooledyou33 is a jewel in the roughspooledyou33 is a jewel in the roughspooledyou33 is a jewel in the rough
Hey guys iam doing a new tranny clutch and fly wheel and short sifter all at the same time can i just put the shoft shifter in the new tranny before i install it or will it be a bitch to line it up into the hole while trying to bolt the tranny in..... thanks for all the help
spooledyou33 is offline   Reply With Quote
Old 04-06-2008, 02:52 PM   #17
FRpilot
FRpilot's Avatar
yes it will be a "bitch" to put the tranny back in b/c the short shifter is going to stick out and hit the tranny tunnel and you won't be able to angle the tranny back in. save it for last b/c you can fill the tranny fluid through the shifter hole, which is big and you won't have to pump the tranny fluid in in like how fsm says to do it.
get lots of towels and cardboard ready. tranny fluid will spew out from the driveshaft hole, even if you drain thouroughly. there will be some fluid that wont come out and will fall out through the back and shifter hole if you tilt the tranny out.
PS. props for searching first. i remember importnut site was a great reference like 6 yrs back when people were doing z32 brake swaps. i used it to install z32 rears.
FRpilot is offline   Reply With Quote
Old 04-06-2008, 03:30 PM   #18
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
^ to add, if you don't want spillage cork the draveshaft hole and plug up the shifter with rags. When I did the 5 speed shop I only did the driveshaft and got some minor spillage from the top because we twisted and turned so that the trans. shaft would line up.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 04-06-2008, 03:58 PM   #19
spooledyou33
dam thanks guys for all the help it will help me out big time when i do the install
Old 03-22-2009, 05:46 PM   #20
whitelinepe
whitelinepe is an unknown quantity at this point
old thread but since its not mentioned isntead of drilling, u can just drop the transmission a little and unbolt the 2 bolts and bolt them back on.
whitelinepe is offline   Reply With Quote
Old 03-24-2009, 03:46 AM   #21
ILoveJDM
since you bumped this old thread
i might as well add i installed a b&m short shifter from inside the car only without going under the car or drilling holes etc.
i do have small hands, but i was able to do it in 30 mins.
Old 08-23-2012, 04:41 PM   #22
OneManDeep
OneManDeep is an unknown quantity at this point
Im having trouble getting the oem shift plate off the transmission, seems like its been gasket sealed on. Any suggestions on removing it without dropping the transmission?
OneManDeep is offline   Reply With Quote
Old 08-23-2012, 04:50 PM   #23
godsmack
godsmack's Avatar
godsmack is an unknown quantity at this point
pry at it with a screwdriver. an angled one would work best.
godsmack is offline   Reply With Quote
Old 08-23-2012, 05:15 PM   #24
OneManDeep
no luck with the screw driver and i dont have a angles one or one i can bend.. ANY other advice?
Old 08-23-2012, 06:23 PM   #25
godsmack
godsmack's Avatar
keep trying. other than that not sure without dropping the tranny.
Old 08-23-2012, 07:46 PM   #26
OneManDeep
Got it done. i went under the car and pounded the plate upward with a screwdriver and hammer.
Old 08-23-2012, 07:47 PM   #27
OneManDeep
thanks for the quick reply too, i appreciate it
Old 08-24-2012, 05:46 AM   #28
94_240sx
94_240sx is on a distinguished road
My experience with this installation.
1. Somehow there's no space at all on my car for the front two bolts, so I had to the bolts on the mount to lower the transmission.
2. If you don't align the gasket right you will mess it up with the bolts. I had to go get another one.
Just my two cents.
courtesyparts.com
94_240sx is offline   Reply With Quote
Old 08-24-2012, 06:37 AM   #29
JFoxx
JFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choices
why is there a thread for this? it took less than 20 min and was one of the easiest mods ive done...... you dont nee to drill holes, get under the car, or drop the trans....i have huge hands and got this done inside the car with basic tools.....
JFoxx is offline   Reply With Quote
Old 08-24-2012, 04:40 PM   #30
godsmack
godsmack's Avatar
^^ i agree. but for some odd reason ppl would rather ask ppl on the internet how to do something rather than use their not so common common sense.
