![]() Join Date: Apr 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
Subframe bushings
I need people that changed their subframe bushings before. What are your recommendation on subframe bushings brand..what are some out there that you guys like?
Any tips on doing it at home? thanks. |
Well, I didn't quite change my subframe bushings, but rather got subrame bushing collars. They're SPL, silver/aluminum, and stiffen up my rear suspension a lot. Ther ride is rougher but I have feel for the road and great control, less bounce and no shake around the corners. Could think about investing in those, 30 minute install and less than $70. Just need a jack set, good breaker bar and 17mm/19mm sockets.
i got mine from ebay, they work good...and its not that hard to do it at home. just get some jackstands, jack, and proper tools for ubolting and your good.
and a friend to help will make it easier
people on Zilvia need a big ol
![]() Join Date: Apr 2003
hrmm...anybody hav a feel with the solid aluminum spl ones?
i kinda want em....but i feel that they will be insane, anybody with some feed back on em?
LP stylez!! bishes Lazy Penguin since teh 04' ![]() Part of the Elite Shasta Speed Stars RIP......05-09-03....*sniff sniff ![]() the beast nears completion..... ![]() YOU LOOK AND U BUY STUFF !!!!! |
![]() Join Date: May 2002
you dont need subframe spacers after bushings are done. wont fit too
anyways iw as going to do solid bushings but i went spacers too , even w/ an extra subframe. talke dw/ some friends and drifters and recommended passing on it for my seutp. so i ewnt that route. got solid rear bushings (s14 subframe) so thats about it. used spacers i got SPL rear ones i would only get SPLparts.com subframe solid bushings if i was though, almost did. |
Dousan PG you got me all confused
Do i still need to change my bushings? or get Subframe bushing collars but not bushings? sorry for asking you questions...and thanks a lot for helping me out. |
get collars/spacers and you keep stock bushings in there (easiest route)
get solid bushings dont need collars (more time consuming/expensive) splparts.com read up bro. |
I love the sh*t out of the spl parts subframe bushings. The rear end use to feel all disconnected, and I could feel shift around. Especially when taking off from stop signs. The rear would feel like it's shifting to the right on regular takeoffs.
Since I got the bushings, I feel the rear is more planted, and doesn't wheel hop. I have noticed a slight increase in noise. I can hear the r/p meshing, and I can hear some gear whine from the trans in the rear end. But it's not over-bearing, or annoying. The exhaust, radio, road noise, and engine noise all cover it up.
Scott Driving Angle Motorsports |
![]() Join Date: Dec 2002
ES sells urethane if you're concerned about noise, and JWT sells Delrin bushings that are midway between the two.
SPL said on website their prev version isnt as good as their nwe one?? and avoid cheap copies
i'd buy spl direct, they support their products 100%! |
![]() Join Date: Feb 2005
Get on ebay and buy some solid aluminum inserts. Put them in the freezer for a night, get a big hammer and smash away. The insert looks like it will never fit, but it does. The factory bushing can be a bitch to get out, I used an air chisel and demolished them. Solid inserts are the way to go, they feel so much better than anything else.
![]() Join Date: Aug 2003
SPL subframe spacers are good... That's the first suspension mod I've done to my car... I used to get a lot of rear-end play, now it is pretty solid.... (not to the level I want it to be...)
U13 and S13 zilvia members are friendly
#17 | |
True, but it's damn hard to screw up a hockey puck of aluminum. I'd see if it was a complex machine or had working or assembled parts, but a subframe bushing isn't any of those.
#19 | |
my impressions = waste of $80 plus your own 20 min of labor. pm me with problemsz |
#20 |
joe: alotta ppl seem to notice the spacers. even xander said he felt a huge ass differnce, and i know guys with decent set ups that swear its one of the best mods to em. ill still pick up a set regardless,
200k bushings on my car....tryin to rid em all out, but dont wanna deal with the pulling of the subframe, etc yet.
#21 |
![]() Join Date: Dec 2004
Get those BUSHINGS!!! I remembered somewhere here someone was saying the bushings are adjustable, but thats balogna! the only way i see them as 'adjustable' would be interchanging spacers/bushings n stuff.
We all learned our first time that Stiff = Better! |
#22 |
well i got the aluminum ones in, from spl, and in about a week ill let you know how it is, but im going to be putting them on as well as coilovers, ruca, tesion rods, and exhaust, so i dont know how ill be able to rate them.
giantroboteyes.wordpress.com/ |
#23 |
when i replaced my subframe, i filled the stock ones with polyurathane, and ran my subframe collars with it.. I unfortinutly dont track or drive my car hard enough to tell the difference from when i just had collars on my old subframe..
heres pics of what can be filled.. Twisting with a screwdriver I dont think its worth pulling your subframe if you dont need to.
Keep it Classy |
#24 |
Planning to poly fill my subframe bushing with my solid subframe collars sometime this weekend. Hope it comes out good.
Any feedback or results from anybody that has done this? Thxz
KEEPIN IT REAL!
#25 |
It is a PITA but I think it was worth it. I put in 300zx subframe bushings and they went in with easily. Get a friend to help you out with it(I wish I did for the first half). But after doing this the car had better response and the noise in the rear stoped.
#27 | |
![]() Join Date: Sep 2006
![]() ![]() Feedback Score: 10 reviews
#29 |
![]() Join Date: Nov 2005
i have the spl solid subframe and diff bushings. they dont bother me at all now but they definitely are loud. you got a bitchy female that rides with you or you just dont want the noise then dont get them. if you can deal with the noise i say go for it. you get to burn shit, use a sawzall, and a BFH what could go better with a six pack in the heat
#30 |
![]() Join Date: Jul 2006
just curious if theres a better solution than dropping the subframe.. i've had the aluminum spacers now for a while but the rubber buishings are making all kinds of noise..
95 SR Zenki | @ e_form daily - A34 Maxima | A36 Maxima |
