Old 12-26-2011, 09:28 PM   #1
Domo40
Domo40 is an unknown quantity at this point
SR wtf is this noise
I need help. my sr20det is making a knocking noise. i believe its a cam but not sure and its not a valve o sumen cuz havent lost power so wtf need to dyno it and wana fix but gta fix dis first.
Domo40 is offline   Reply With Quote
Old 12-28-2011, 11:06 PM   #2
RandallSharp
RandallSharp's Avatar
RandallSharp is an unknown quantity at this point
Cams generally tick (valve tick). Knocking is usually in the block.
If the block is knocking, don't answer it. It's almost always bad news bears.
1991 240sx Hatch Daily'd!
RandallSharp is offline   Reply With Quote
Old 12-29-2011, 09:05 AM   #3
Sileighty_85
Sileighty_85's Avatar
if the knocking gets louder and faster as RPMs increase then you spun a rod bearing
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 12-29-2011, 01:20 PM   #4
Mercury_Hg
Mercury_Hg is an unknown quantity at this point
Mine developed a minor ticking after accidentally running the timing too far advanced. How to fix this?
Mercury_Hg is offline   Reply With Quote
Old 12-29-2011, 02:46 PM   #5
starplatnumm
starplatnumm is an unknown quantity at this point
I have same problem too. It turns out that while I started using synthetic oil. a knock occurred due to lite engine oil. The Sr was used to conventional oil. Back in 1991 the sr20 was designed for conventional. Ester oil or motul may leave a protective film but is too thin for your journal clearance. Reason why we take synthetic oil is cause it runs great on our turbo and it cools better. Unless you have the new 370z or maxima its official due to tighter clearances. Also by doing so you cannot revert back to conventional cause it your knock will worsened
starplatnumm is offline   Reply With Quote
Old 12-29-2011, 03:36 PM   #6
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Did you fix the timing already? You sure its not rod knock? If its a rod knock, it should be faint at idle. When you slowly rev the engine, you will hear when it hits its "sweet spot." Usually around 3k-3.5k.
CLICK HERE!!!
Old 12-29-2011, 03:43 PM   #7
Mercury_Hg
Yup.
Pretty sure. Sounds like it's coming from the head. It doesn't really increase in volume at faster RPMs, it just occurs faster (obviously). Reminds me of a ticking lifter that I had in my Eclipse. Running higher viscosity oil lessens the noise. Valve is what I'm suspecting, but I'm intimidated by the head.
Old 12-29-2011, 11:01 PM   #8
Domo40
Wen I warm it up dsnt hapen wen da cars warm it starts. Da higher da rpm da louder it is I let go of gas and it goes away and at idle u barely hear it. And yes I changd da oil and it startd da noise im thnking of changing all cams and timing belt but not sure if dats it. Also ive herd its da cmt cam o sumen like dat?
Old 12-29-2011, 11:03 PM   #9
Domo40
Its not a rod cuz its hapend to a old car ive had
Old 12-30-2011, 12:20 AM   #10
RandallSharp
You're going to have to use correct grammar and spelling if you want more assistance or provide us with a suitable translator.
Old 12-30-2011, 12:58 AM   #11
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
bleed those lifters y0
Old 12-30-2011, 05:01 AM   #12
Mercury_Hg
Does this apply to a KA24DE?
Old 12-30-2011, 01:38 PM   #13
RandallSharp
The KA24E has hydraulic tappets, so I suppose the Twin Cam version may too? I'm not sure.
Old 12-31-2011, 05:09 AM   #14
ericm9104
ericm9104 is an unknown quantity at this point
Dual cam Ka's don't have lifters.
Sent from my SPH-M910 using Tapatalk
ericm9104 is offline   Reply With Quote
Old 12-31-2011, 09:23 AM   #15
fliprayzin240sx
KA head design is better than the SR head design. Hydraulic lifters just suck plain and simple. Took Nissan almost 10 yrs to figure it out and finally got rid of the hydraulic lifters out of the SR20 Neos.
Back to the OP, do you have an oil pressure gauge? I'm just curious what your oil pressure is at, when it starts ticking. I'm pop the valve cover off and see if its still got the chain protector crap, chain could be loosing tension and slapping on that thing. Also, what oil do you use and weight.
Lastly, stop typing like retard in here...fastest way to kill folks motivation in helping you out is by typing like a 5th grader.
CLICK HERE!!!
