Using Break-In Oil on Freshly Built Head?
Freshly Built ‘95 KA24DE Head
- Brian Crower Titanium Seats - BC Valve Guides - BC STD size Intake and Exhaust Valves - BC 264/264 Cams - BC Dual Valve Springs - Mahle Valve Seals - Jim Wolf Adjustable Cam Gears - Brand New Timing Chains and Guides Untouched/Stock Bottom End Goal of this “Build” is really to just get the car running. No drifting or high revving in mind. Parts and upgrades are purely for safety, longevity, and reliability. My question is.... would it be necessary to use a Break-In Engine Oil? I know people use it on rebuilt engines to help with the seating of the piston rings and for the added protection during this critical and early stage of engine’s new life. But they also use this type of oil to live and protect valvetrain parts as well. Just looking for a second opinion and thoughts within the community. Thanks. Sent from my iPhone using Tapatalk |
The flat tappet oil has higher levels of zddp which aid in the break in of our camshafts in DOHC engines
It's what I have used to break in my last 5 built SR engines, including 2 VETs. It's also what my machine shop recommended (they build all the spec miata engines, Porsche engines and thier pro stock engines). So yeah, if you have another recommendation king, let's hear it. Goodluck OP. |
Ps OP
This is straight from the maker of the cams Brian crower . But since king knows all, dont pay attention to what the cam manufacturer says and listen to the all encompassing wisdom of king..... Quote:
#8 | |
Oh and it gets even better....
![]() Join Date: May 2019
Always used. What manufacturers set for oil weight, 500miles, then change oil, cut open oil filter to inspect for debris...next change at 1500 miles, do the same with filter..if all good... change oil regularly
#11 | |
Dude thank you for this. Been try all day yesterday to open that damned link and I’ve been getting 404 Errors left and right. On another note, kinda bummed out cause I put fresh Amsoil in recently and I just took the head back off to get work done and now gotta drain and put break in oil lol but thanks a lot! Sent from my iPhone using Tapatalk |
![]() Join Date: Jul 2005
Never heard of that. Hmmm. If you find evidence from any other manufacturer than Brian Crower I might be tempted to believe it. But it sounds like a joke to me given that the camshaft is not intended to generate a wear pattern. The proof is that you can swap them from engine to engine, valve to valve, rocker to rocker, without consequence.
I could be wrong but I think whoever wrote that about BC 'break in additive' was not an engineer, and trying to sound 'smart' by giving potential misinformation. I'd go out on a limb and suggest you try contacting greddy, hks, those name brands in effort to establish what they recommend for new camshafts. If for no other reason than to gain a reference point of view. |
#13 | |
Personally, I'm more likely to obey my own paranoia, than howard or brian's paranoia. Moly grease (real assembly lube or otherwise) all over the lobes, buckets/shims/keepers/etc, thinner lube in lifter/bucket bores, take it for a spin and whenever you and all your new parts are happy, change the oil. Of course, yeah, cams shouldn't wear in much, it's just very light burnishing, I think the fear is that if it goes wrong before the parts are entirely happy, you get runaway scuffing and wipe it (and the motor) before you know what's happened. The most important part of any automotive repair is to maintain the loose nut behind the steering wheel. Do whatever makes you feel warm and fuzzy inside. |
#14 | ||
Just out of curiosity,
If you search about 'roller' style cams and break in oils, you find stuff like this, https://www.corvetteforum.com/forums...post1593096911 Quote:
You can also find alot of info from people suggesting the use of 'break in oils' and so forth. It goes both ways on the sea of internetz. Personally after everything I've seen and done, i.e. using new and used roller cams and sr20 cams with straight synthetic and no issues, this is how I play the game to this day. My simple claim is that, if the part can be moved from engine to engine, then it does not contain any established personalized wear pattern, and thus the use of synthetic motor oil is indifferent/inconsequential. Basically the less it wears the better, and synthetic does a great job of preventing wear. I think break in oil is a mistake in this instance. |
#15 | |
Bull flows all ways, but there's a higher truth we can pick out...
Roller rockers shouldn't break in, piston rings absolutely must. ZDDP is only one of a variety of chemical magicks, and most oil is oil is oil and will work, even very well - but so what? You need SOME wear limiting additives, who cares if they put the name everyone knows on the front? Extra zinc helps because oils have dramatically less zinc than would be good, because of catalysts. Ever wonder why only API SH/SJ oils are specced for old gear/transfer cases and trannys? I doubt it's because modern oil has as much catalyst poisoning zinc in it as it can possibly use. Also, shim buckets are not rollers, they're basically....... flat tappets. |
#17 | |
I can't dismiss the overwhelming evidence from variety of cam manufactures that says not to use synthetic oil for break in procedure of camshafts. I stand by my original recommendation of using the cam manufacturer's recommendation lmao I do recall that on 2jz-gte you want the conventional motor oil for a new camshaft. Something about ductile billet materials... fwiw It still seems strange to me that you can pull a used cam out of an SR/2jz/LS engine and re-install it into a completely different engine without using any kind of break in procedure 'just because its already been broken in on another engine' is that even why? or how? idfk finally I want to thank everyone who contributed and all thoughts involved, it was nice ![]() |
![]() Join Date: Mar 2009
Pretty sure Amsoil has tested their oils against other brands and proven better resistance to component wear. Just responding to that quote from the corvette forum.
