Old 02-04-2017, 05:30 AM   #1
Sr20probs
Sr20probs's Avatar
Sr20probs is an unknown quantity at this point
Sr20det assembly and tuning ideas
Hey guys I have a few questions about my build I'm doing.
Sr20det redtop
-forged Mahle 86.5mm 8.5:1 pistons
-forged eagle rods
-ACL bearings
-cometic headgasket
-oem headstuds?
-oem main studs?
I'm going to assemble the bottom end and was wondering if anyone has any trouble with the arp main studs I may go oem by arp seems to be my best bet while I'm in there. I was curious if anyone had any issues with them. What's the best assembly lube to use? Also I was considering having rs enthlapy tuning my ECU. Just posting ideas that's all looking for opinions thanks
Sr20probs is offline   Reply With Quote
Old 02-04-2017, 05:46 AM   #2
gaz_moose
gaz_moose is an unknown quantity at this point
I know of a fair few people that have had trouble with cometic headgaskets.
what power are you aiming for?
the arp main studs put my caps out of round. I wish I would have saved myself the hassle and just used oem main studs.
you can just use ep90 gear oil as assembly oil. or just engine oil.
gaz_moose is offline   Reply With Quote
Old 02-04-2017, 06:00 AM   #3
Sr20probs
Sr20probs's Avatar
I was aiming for around 300-350 as I plan on dailying it. I can't seem to find a set of oem main studs. I've read the arp can give trouble.:/
Old 02-04-2017, 06:13 AM   #4
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
ARP main required an align hone and not many machines shops are capable of doing this with the SR block (Mazworx can however).
ARP head bolts may be incorrect (too shot). Use Mazworx
Everything else looks good. Make sure to have good tools to take various measurements (bore out of round, bearing, etc etc)
Old 02-04-2017, 06:18 AM   #5
Sr20probs
Sr20probs's Avatar
Where can I get a set of oem mainstuds? I don't want to reuse the old ones. Block is currently st the machine shop getting decked and bored. Thank you.
Old 02-04-2017, 08:14 PM   #6
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
You can re-use the OEM mains, they're not torque to yield. ARP main studs, or any aftermarket ones for that matter will distort the main caps and require machining, also a take away note, ARP main studs for the SR20det are actually designed for the FWD block and oil pan, so you have clearance issues with the oil pan on a RWD det block. Mazworx main studs don't have that issue
[email protected]
hanzbrady is offline   Reply With Quote
Old 02-06-2017, 06:14 AM   #7
Sr20probs
Sr20probs's Avatar
What about the headgasket size I have a 87mm I bought previously but oh to bore the block to fit 87mm pistons, would I need a 88mm headgasket or can I run the one I have?
Old 02-06-2017, 06:35 AM   #8
hanzbrady
hanzbrady's Avatar
you would run an 87mm-87.50mm head gasket.
[email protected]
Old 02-06-2017, 06:38 AM   #9
RalliartRsX
Trader Rating: (32)
hanz, would that also be the case if the block is bored to 86.5mm?? Would you run a 86.5-87mm head gasket??
Old 02-06-2017, 06:39 AM   #10
hanzbrady
hanzbrady's Avatar
Yes. msglength
[email protected]
Old 02-06-2017, 06:45 AM   #11
2_Liter_Turbo
2_Liter_Turbo's Avatar
Trader Rating: (28)
2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough
Feedback Score: 28 reviews
I run ARP mains, and never had any issues. I had the block machined for them though, lol.
96 S14: Grip Track Car
90 R32: Bucket List Car
92 S13: Just for Fun Car
Instagram: @SS.Maxey
2_Liter_Turbo is offline   Reply With Quote
Old 02-06-2017, 06:54 AM   #12
Sr20probs
Sr20probs's Avatar
So you don't think I have to buy a new headgasket to run the 87mms?
Old 02-06-2017, 08:20 AM   #13
hanzbrady
hanzbrady's Avatar
You should always use a new one, however; if you're very strapped for cash and have a good quality MLS gasket you can re-use them.
[email protected]
Old 02-06-2017, 08:37 AM   #14
Sr20probs
Sr20probs's Avatar
I have it brand new in the box 87mm but just worried bout heat expansion I read you should run .5-1mm over the bore size.
Old 02-06-2017, 09:31 AM   #15
hanzbrady
hanzbrady's Avatar
That's why the hole in head gaskets aren't exactly their advertised bore size, they're always slightly larger, also your engine bores aren't growing .5- 1mm from heat expansion, they hardly move and if they do it's by thousandths of an inch. You will be fine.
[email protected]
