![]() Join Date: Jan 2004
300zx brake master middle fitting??
The middle fitting had that stupid plug in it, so I removed it and it there is no fitting inside it. if I install it as is its gonna leak for sure. so I read I could dremel my old 240 master and use the pressed in fitting from that. well I dremeled it only to find out I had the one peice cast 240 master cylinder, there is no pressed in fittings.
Then, I was searching ebay and found this http://cgi.ebay.com/ebaymotors/ws/eB...ksid=p3907.m29 bought it, tryed installing it, it threads into the 300zx master fine, but the stock fitting on the brake hardline doesnt have the same thread pattern as the female end on that ebay fitting. so I cant use it. how else can I install the middle brake line without having it leak?? can I reflare somehow to seal? anyone experienced this?
s13 parts fs:#/f/showthread.php?t=193416 sr parts fs: #/f/showthread.php?t=193399 s14 parts fs:#/f/showthread.php?t=193420 180sx part out #/f/showthread.php?t=203711 |
this is for my s13 trak car, non abs. anyone have anther solution then getting that pressed in fitting from an old mc?
![]() Join Date: Dec 2006
Ive heard the Z31 MC is the same bore size as the Auto S13's with the correct line hook ups.
yea it bolts up fine, but there is no face for the hardline's fitting to seal on. yours is prolly leaking..no?
![]() Join Date: Dec 2002
Sorry dude, thats crappy. You do need that press in fitting for the flare. It may not leak at first without it but it will sooner than later.
No... no one stole my interior... its safely in my garage...
![]() Join Date: Jan 2005
i used that ebay fitting on mine
its not that its the wrong threads its that they are too thick i ran a tap through it and it bolted up just fine no leaks either
Need automotive work done in the antelope valley? Ask me how i can help. |
what size tap did you run through it? Im gonna try this.
you can do what i did and re-flared the middle hard line to a bubble flare inorder to work with out a fitting.
this was the kit i used http://cgi.ebay.com/ebaymotors/_Auto...3756.m20.l1116 |
i think it was 10x1.00
the inverted flare works good too and is easy to do
so you either find a flair fitting or flare your hardline? is this right?
I thought the hardline is already flaired? why do we need to flair it more? I'm looking to do mine soon, so thank for the help guys |
#17 |
you re-flare it with an iso style flare
it looks like a bubble so it seals against the inward face of the bmc as opposed to sealing against the cone of the insert ![]() you can probably borrow the tool from autozone
how do you put in the bmc? mine bmc doesn't have the rod that's sticking out from the cylinder and goes into the booster. Can I reuse the 240sx rod and how do I connect it to the booster? thanks
#21 |
I picked up some 3/16" brake hard line approx 6inch lenght and bought a brake line flaring tool cut one end and bubble flared it. Shaped to fit and cut the factory hard line and reflared it and installed a union (not a compression fitting) works great.
#22 | |
![]() Join Date: Jul 2008
ok i also found that z31 bmc's fit is it worth to go out and buy that or just reflare? i would guess that the bmc i have would def be better but does anyone have first hand experience with both?
![]() Quote:
#23 |
![]() Join Date: Apr 2007
Yeah I had the same problem and I purchased an aftermarket BMC that was supposed to already have all the fittings in place. Man what a pain.
I ended up just cutting the fitting out of my stock S14 BMC and tapping it into The Z middle port. I heard that if you use a bubble flair rather than the double flare it might seal (?) importnut.net I think had some good info on this.
#24 |
LOL. Like many of you guys here,
I am the Z32 brake master. If you've done dozens of Z32 brake swaps, you are probably like me. I have these two extra fitting sitting in my Freezer, ready to go. Why freezer? Metal shrinks. Wink Wink. I charge all my friends PREMIUM, just for the fittings because the effort it takes to get them are worth what I charge. Installation is delicate, I made a custom rod out of a flared hardline to hit the fitting in. Then use a piece of hard line with the threading and screw it one. I mastered it. Why buy ebay shit, when OEM is best. LOL. OEM FITMENT OWNS ALL. NO MODS. |
#25 | |
can anyone hook me up with a fitting please!?!?
![]() Quote:
