![]() Join Date: Aug 2009
![]() Feedback Score: 27 reviews
S13 KA24DE "Hunting" for idle, still idles with idle speed screw shut
Now that my car has an OEM airbox and filter on it, it will stay running on it's own but it still has some issues. It doesn't like to run at 20 BTDC, it runs best at 30BTDC and when I move it to 20 BTDC while it's running the idle speed drops alot and it begins trying to die, so I open the IACV screw and it doesn't help, even with the screw almost completely out the idle is still low and weak. Brake booster is not even hooked up, and the port is capped, and doing this made no difference in idle. Also my intake manifold and air tube hold 9psi of air without leaking at all.
What I know: intake manifold and everything behind the MAF holds 9PSI with absolutely no leaks anywhere, tested yesterday. fresh gasoline in it good fuel pressure, 30-40psi makes no difference Engine harness is good, tested 2 of them MAF seems to be good, tested 2 of them Timing chains are correct, cams are correctly timed, 248/232 "hot cam" swap (I have done this many times with no issues, ever) TPS resistance is good, 2-10ohms @ 0-90 degrees ECU is good, tested 2 of them IACV is good, tested 3 of them Distributor is good, tested 3 of them Ignition coil is good, tested 2 of them Igniter chip works Coolant temp sensor is good, ohm tested it, and tried 2 of them O2 sensor is brand new bosch, unplugging it does not help. Injectors are good, replaced all 4 injectors, O-rings are good Brake booster vacuum hose is good and sealed, with a check valve All 2 vacuum lines used on this engine are good ISR EGR block off plate installed Emissions & EGE removed Code 55 on the ECU (no faults) Throttle body is clean and gasket is new & sealed with a tiny amount of RTV Intake manifold lower PCV ports are welded shut IACV hose is new and sealed well Air regulator valve hose is good, no cracks Ignition timing is good, 20BTDC Spark plug wires are brand new NGK Spark plugs are new NGK BKE5E-11, replacing the spark plugs actually made it a little bit harder to start. S14 longblock with all S13 parts on it. S14 upper intake manifold, S13 lower intake manifold. |
Are you setting idle speed correctly? You aren't supposed to just adjust the screw.
Unhook TPS Harness, crank car, adjust screw, turn car off, connect TPS
![]() 5.3 V8 Swap w/ Nitrous |
I figured it out, I was lucky enough to come across 3 bad IACVs. I bought another one after hooking up a consult scanner and reading all the sensor voltages.
The problem was that the IACV was stuck open and causing an internal vacuum leak from behind the throttle body to the intake tube and since it was internal, it did not show up when you boost/vacuum leak test the intake system. FIXED |
