Headlight Problem
Hi I have a 91 240sx coupe and I did the sleepy eye mod when I first bought the car about 3 years ago. I did it by taking off the relay on the right front side of the car and jumping the wires hooked up to switches. It worked fine until now, I checked my powers and grounds and I checked every single fuse in the car until I found out I had a blown fuse right next to that relay. I hooked up a fuse and removed the sleepy eye mod then installed the relay back up. Now, one headlight goes up and the other goes down, I then hit the headlight switch and one goes back down and the other goes down. Has anyone had this issue I swapped relays and nothing happened.
