![]() Join Date: Feb 2010
sr20 revs slow
ive noticed that compare to other sr's mine doesnt rev up as fast,
almost like the flywheel is too tight its a blacktop, t25, fmic godspeed , hks bov, spec 2 clutch the car runs and boosts fine, it just climbs through the rpms too slow anybody have any ideas what could be causing this problem? could it the something w the flywheel??? |
vac leak where??? i know my way around ka but im kidan new w sr's, i dont see alot of vacuums though
how can i check if the tps is misplaced??? i did take off my intake manifold when i got the motor because it had calcium buildup how can i check the timing??? idk if the motors been opened before so idk, it looks pretty stock im running the car at 10lbs and still feels pretty stock =( helllpppp |
id def. check for a boost leak
as for the tps, its located on the right side of the throttle body, it should have a red connector, but check it for bent pins i knew a buddy who bent one whop had kinda the same problem
'92 240sx w/'93 SR Blacktop /// '94 RX7 FD3S /// '11 370z RIP |
![]() Join Date: May 2008
You should do a compression test to make sure your engine is still in good shape.
And there is nothing wrong with your flywheel... Frank
Life is a beat to beat |
after lookiing at the engine bay for 20 minutes and making sure everythign was bolted on right i found that the o2 sensor wasnt crewed all the way in =/
that made a lil differences, then a friend came by and we realized and i would give it full throttle the throttle body wouldnt open all the way so we fixed that =) ima check for a boost leak tomorrow at a this guys shop thanks for the replies im kinda new to sr's, be patient ill catch up pretty fast =) |
