Old 04-29-2009, 06:30 PM   #1
Shadowhunter
Shadowhunter's Avatar
Shadowhunter is an unknown quantity at this point
s14 Subframe Reinstallation Question
To you guys who have removed and reinstalled the rear subframe.. Is it easier to install just the subframe first or do you guys find it easier to install with the rear diff attached? I know the rear diff is heavy but it seems like it would be a pita to install on it's own later on as well. Thanks in advance.
Shadowhunter is offline   Reply With Quote
Old 04-29-2009, 06:33 PM   #2
Marcus
Marcus's Avatar
Trader Rating: (18)
Marcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfection
Feedback Score: 18 reviews
im doin it this weekend. ill let you know.
from what i hear, reinstall all together. im gonna try that
Marcus is offline   Reply With Quote
Old 04-29-2009, 06:35 PM   #3
Logan
Logan's Avatar
Logan is an unknown quantity at this point
Send a message via AIM to Logan
When I did mine, I did the subframe minus diff carrier
If you have a lift or something, then you could rest the whole subframe assembly on a dolly and drop the car on it (which I've seen done before), but if you doing in the home garage, probably best to do minus diff carrier
Installing rear diff carrier by itself isn't "hard" in the grand scheme of things
Logan is offline   Reply With Quote
Old 04-29-2009, 06:44 PM   #4
S14DB
AFC #1
S14DB's Avatar
I have found it easier to install with the Diff installed and jacking the subframe up using the diff. I found it hard to jack the subframe up without the diff installed.
Old 04-29-2009, 07:00 PM   #5
travypoo
travypoo is an unknown quantity at this point
Send a message via MSN to travypoo
i just recently did it, had the whole thing together. got a friend to pick up on one side and i slid the jack onto the diff and balanced it.
travypoo is offline   Reply With Quote
Old 04-30-2009, 05:21 AM   #6
supreme_1
supreme_1 is on the path to ruinsupreme_1 is on the path to ruinsupreme_1 is on the path to ruin
It all depends on what tools, resources, and man power you have. I have always found it easier to install it all at once. trying to get a diff up there when its on your stomache is fairly difficult, none the less heavy as fcuk
supreme_1 is offline   Reply With Quote
Old 04-30-2009, 11:42 AM   #7
brndck
brndck's Avatar
Trader Rating: (129)
Feedback Score: 129 reviews
its easier to install the subframe with the diff already bolted to it. that way you can use the diff as the jacking/lifting point.
Old 04-30-2009, 01:39 PM   #8
Gription
Gription's Avatar
Gription is an unknown quantity at this point
Send a message via AIM to Gription
All I remember from when I did mine is it was really heavy.
Gription is offline   Reply With Quote
Old 05-01-2009, 08:23 PM   #9
mojos13
mojos13 will become famous soon enoughmojos13 will become famous soon enoughmojos13 will become famous soon enough
I, did it twice on my S14 all by myself ( leaky fuel tank ) do it all together for sure!, it's heavier but in the long run, you'll be done much quicker.
mojos13 is offline   Reply With Quote
Old 05-02-2009, 10:47 PM   #10
caLi2fortee
caLi2fortee is an unknown quantity at this point
When I did mine, everything was installed, minus the axles.
caLi2fortee is offline   Reply With Quote
Old 05-02-2009, 10:51 PM   #11
jorge1190
jorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to all
Do it with the diff on. Its good jacking point just make sure you have buddies to stabilize it and line it up. The diff is not easy to press up, line up and then push back. I have done both
jorge1190 is offline   Reply With Quote
Old 05-02-2009, 11:34 PM   #12
ae13bravo
ae13bravo's Avatar
ae13bravo is a name known to allae13bravo is a name known to allae13bravo is a name known to allae13bravo is a name known to allae13bravo is a name known to allae13bravo is a name known to allae13bravo is a name known to allae13bravo is a name known to allae13bravo is a name known to allae13bravo is a name known to allae13bravo is a name known to all
Send a message via AIM to ae13bravo Send a message via MSN to ae13bravo
I did it without the diff about 2 years ago. It was a real pain trying to get the diff on by my self. I suggest you try it all together. Which reminds me I have to install my diff. solid alum. bushings once I get back to the states.
Help me find a Top Garage Rear Bumper!
#/f/private-sellers/...ae13bravo.html
ae13bravo is offline   Reply With Quote
