![]() Join Date: Nov 2003
accessory pullies? (Megan vs. Isis vs. Circuit Sports)
So, of the knockoff companies...are any of them any better or worse than the others?
I have an S13 SR20, and want some blue accessory pullies. But dont want to spend 'Greddy' money on them, but dont want complete bullshit either. Any reason to get one of the sets over the other?
-Kyle |
![]() Join Date: Jun 2003
Trader Rating: (129)
Only if u had extra $ to waste. The I can't see any reason to pay more for "brand" ones. I have circuit sport pulleys and they perform fine for the last 3 years.
To tell you the truth, I rather spend the money on the name brand ones than risk something happening to my engine. But starting this thread is a good idea because you can get feedbacks from everyone on what they have.
Well right, I have name brand everything else. But there is a 300 difference in price between the Greddy pullies and knockoff's, and accessory pullies arent THAT big of a deal. Not like an Oil pan or something.
-Kyle |
your accessory pullies drive you ps pump, alt, and water pump. A spent belt isn't going to blow your motor but you will be stranded. I bought a knockoff pulley set(maybe obx?) for my S4. Ate belts if tightened and squeeled constantly if too loose.
![]() Join Date: Apr 2006
whatever pulley you idiots buy and install, i suggest checking the runoff. it wouldnt surprise me if the knockoff stuff wasnt straight
Well, educate me here folks. I have never bought knockoff parts before, thats why I made this thread. I have always run legit shit, and never had to read or learn about it, I just knew it was quality shit. This is my first endeavor into this, so I was seeing if any has had bad experiences with it or not. If so, I'll just leave them stock.
-Kyle |
What Mike is implying is that the parts
may not be 'round' and wobble when in use causing vibration and bearing shorten life when mounted, use an indicator on a stand and check how much deflection there is as you turn the pulley something like this: ![]() and the term is really run-out |
#17 | |
![]() Join Date: Nov 2004
Stock gauges work fine.
#18 | |
manufacturers make cars to operate under normal driving conditions most cars spend their lives well below redline ~2.5 - 5k oem pulleys are designed to operate in this range now, it is well documented that SR water pumps cavitate at high RPMs i.e water pump stop flowing -> serious problems the problem is address by an aftermarket pulley that is larger in diameter in order to lower the working ratio on the pump. i.e. slow it down same thing goes for alternators and power steering pumps they don't work any better at high RPM you only risk bearing damage larger pulleys slow them down so in summary: aftermarket pulleys on your daily driver/hardparker = you're a ricer aftermarket pulleys on your track car = you're doing it right |
#19 |
Ok, yea, this is a dedicated toy car. Gets driven on the street, but usually pretty abusively lol.
Do the Circuit Sports ones actually have diameter changes though to make up for what your talking about?
-Kyle |
#24 |
![]() Join Date: Jan 2008
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 14 reviews
I have had both circuit sports and greddy pullies and my altenator pulley from circuit sports just spun freely one day. Everything was legit but the pulley just self destructed. I switched to greddy and never had a problem after that. Sold the car. 5 years later the current owner still says everything is perfect. Its worth the cheese for the nice stuff. I basically always ask. If there is failure will my motor be at risk? If so spend that cheese don't stack it. I guess some of us get lucky and some don't. But for sure check the run-out.
#25 |
you guys can spend a lifetime checking this and checking that when it comes to cheap shit
last month, you fucking retards were celebrating when you heard HKS was closing its doors here in the US, while us old-schoolers were sad and disappointed. the problem here is that we have a plethora of shit-for-brain 240 owners that dont appreciate good companies, support shitty quick-to-knockoff companies... and cant fabricate something on their own if their life depended on it. bottom line, the majority of the 240 owners here will not benefit from buying a pulley set, regardless if its OEM or aftermarket. its just not a worth-while mod, its pretty pointless for any street car. furthermore, the majority of car owners in general would benefit more from driving lessons than they would from a fully built motor or 10,000 dollars in parts. people dont even understand the changes they make when they install parts... good or bad, its all considered an upgrade. i wonder who here will even understand what im saying. probably juan and dave, thats it. |
#27 |
Ixfxi and zar. I couldn't agree with you guys more. I truely wish there were no knockoff companies because then the "scene" as they say wouldn't be so flooded with these young kids who have no clue. But there are knockoff companies so this is what we have to put up with. I remember researching 10 years ago to find other cars' oem pulleys that were larger but had the same amount of ribs and using them as underdrive pulleys. Or just buying expensive brand name stuff. There no cleverness left with the knockoff companies butthere is a huge market for them so they are here. Also really when you think about it is it really needed to spend tripple the price on something like a catchcan or a coolant overflow tank? No. If you do its really just an elitest mindset some people have that makes them feel better. I know plenty of people who spend a lot of money and can't drive for a damn then on the other side I know several people who run knockoff everything and drive like bosses. Its all made in the same places anyway for the most part. Its just private label.
#28 |
if the quality is there, i could give NONE fucks about what the name of the product is.
yes its shitty that hks has closed its doors stateside, but the truth is, we have some companies stateside that are working to improve their products and their quality. (i'm not saying that all u.s. brands are shit or that all are golden, but just because its not hks, greddy, yashio, etc, doesn't mean its not worth buying) i'm sure if you bought an hks product in their first year it left something to be desired. |
#30 |
![]() Join Date: Jan 2010
Trader Rating: (24)
![]() Feedback Score: 24 reviews
you could just have the stock pulleys powder coated if you care about the blang blang
my for sale thread: #/f/sale-items/53975...e-30-less.html NISMO, NRG, JDM turn signals, misc engine parts |
