Old 10-15-2006, 02:52 PM   #1
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
help with tranny swap
ok guys rite now i have an 89 hatch auto
i bought another 89 hatch 5spd
wat im trying to do is swap over the tranny. from wat my frends have told me. it s not a simple task to swap the tranny. i thot it would take a few days time (3 max) but they said it is difficult if u dont take the motor out too. they recommend that i pull the motor and the tranny out.
wen i install it, they said it would b hard to install the tranny alone from the bottom. they say if i take out the motor it would be easier
but the problem i have is rite now my car is my DD. if i do this swap, i wont have a car to go skewl/work. do u guys think if i take out the tranny alone, how long would it take and how difficult it would be. from wat i read here on zilvia, it should take 2 days max?
lexus baby
5t341tH is offline   Reply With Quote
Old 10-15-2006, 03:24 PM   #2
Ninjabread
Ninjabread's Avatar
Ninjabread is close to perfectionNinjabread is close to perfectionNinjabread is close to perfectionNinjabread is close to perfectionNinjabread is close to perfectionNinjabread is close to perfectionNinjabread is close to perfectionNinjabread is close to perfectionNinjabread is close to perfectionNinjabread is close to perfectionNinjabread is close to perfection
Send a message via AIM to Ninjabread Send a message via MSN to Ninjabread
I would also like to know what the easiest way of swapping the tranny is (unbolting and dropping out, or taking the motor out with the tranny from the engine bay) because i'll be doing that sometime next spring due to a fucked up 2nd gear synchro. The difference (maybe) is I will have access to a shop lift and equipement, so i suppose dropping just the tranny would be the easiest thing to do.
Sorry, didn't intend to thread jack.
613DriftWerks.ca
Ninjabread is offline   Reply With Quote
Old 10-15-2006, 07:47 PM   #3
projectRDM
projectRDM's Avatar
Realistically it's a full day job, but a person well inclined and knowledgeable can do it in about three hours, start to finish.
Judging by your shitty ass grammar and spelling skills you're looking at three weeks, at least. Maybe more.
You might also try getting off your lazy ass and actually researching the question instead of hoping someone will spoon feed the answer to you.
Old 10-15-2006, 09:39 PM   #4
Duzzes_Wild
Duzzes_Wild can only hope to improve
well me and a friend swapped motors from our two cars and are ready for wiring in 6 hours that means pulled em out and bolted em up took harnesses out of both and now is just in need of a few jumps and tweeks and will be ready
p.s- one was a auto car that had been converted but still has auto harness
Duzzes_Wild is offline   Reply With Quote
Old 10-16-2006, 12:31 AM   #5
5t341tH
5t341tH's Avatar
did u guys pull the tranny from the bottom out alone, or did you pull the tranny along with the motor?
lexus baby
Old 10-16-2006, 09:31 AM   #6
HalveBlue
HalveBlue's Avatar
HalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond repute
If you have proper tools, a lift, and some manpower it'd probably be easier to just unbolt the tranny. However, if you're looking at the doing most of the work by yourself, in your garage, it'd probably be easier to just take out the whole engine with the transmission still bolted on.
I did it, by myself, in about 3-4 hours.
The advantage to taking out the motor and tranny together is that you have a lot more room to work with and you can check to see if there's anything else that needs to be fixed/cleaned.
As long as you have the proper tools you should be fine.
HalveBlue is offline   Reply With Quote
Old 10-16-2006, 10:14 AM   #7
ComptonAssDaniel
ComptonAssDaniel is on the path to ruinComptonAssDaniel is on the path to ruin
You probably shouldn't guess these things. Contrary to what you "thot", you should probably start out with a plan of how you're gonna tackle it first, parts you may need, then estimate how many days it will take from there, even with a day or two buffer time. That way you'll get everything done in an orderly fashion, and very smoothly.
It would definitely be easier to take it out all together, but by the sound of it, it seems like you are inadequately prepared to handle such a task. If this car is your daily driver, then maybe you should make plans on how you're going to get to work or "skewl" if your car is going to be out of commission.
...Maybe you can save time by not going to school. It doesn't look like you're learning anything there anyway.
Do you think if I go to a junk yard and get parts to build my own airplane, how long would it take, and how difficult would it be?
I mean, do you see where I'm coming from? It entirely depends on your level of experience and tools you have at hand. It all depends on the person. Some people can install an entire turbo setup in a day. It took me about a week and a half!
ComptonAssDaniel is offline   Reply With Quote
Old 10-16-2006, 12:18 PM   #8
5t341tH
5t341tH's Avatar
ok thanks guys. yea now i realize that i shouldnt really base wat im going to do on your experiences. my skills are different so it might take me more or less time.
sorry about the way i type. its online talk.
lexus baby
Old 10-16-2006, 12:31 PM   #9
steve shadows
steve shadows's Avatar
steve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfection
Send a message via AIM to steve shadows
You just need one tranny swapped wtih the other? 200 bucks ill have it done for you in 2 hours...
Like Me on FaceBook !
steve shadows is offline   Reply With Quote
Old 10-16-2006, 06:24 PM   #10
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
I wrote the auto to 5 speed swap faq in the Archive and Faq section check it out. It tells you everything you need to do and parts for the swap.
If you have a lift then drop the auto tranny its easier that way. You do not need to pull your engine.
New Video
Buy my mounts!
Old 10-16-2006, 06:27 PM   #11
Ninjabread
Ninjabread's Avatar
Thanks man... those were my thoughts, just needed to confirm
613DriftWerks.ca
Old 10-16-2006, 06:41 PM   #12
92FireCoupe
92FireCoupe's Avatar
92FireCoupe is an unknown quantity at this point
Thumbs up tranny swap
I've done this. I'm mechanically inclined, but a freind and I done this in a couple afternoons(after school and work.) time. You'll need a demel and patience... Probably a new clutch line because the fittings are brass and it is hard to break them out of the sockets sometimes without rounding them off. I think if you're patient you're capable. Just research it! Good luck and let us know how it turns out...
I have a freind who is desperately in need of an S13 rolling chassis. Engine is not neccesary
92FireCoupe is offline   Reply With Quote
Old 10-16-2006, 06:47 PM   #13
projectRDM
projectRDM's Avatar
The line fittings are NOT brass, they're just a softer steel than anything else. That's why they make flarenut wrenches.
